Jetting? #1354970
12/18/12 02:21 PM
12/18/12 02:21 PM
nc
E
emarine01 Offline OP
E
nc
Whats the deal with Holley jets #s 88 /89 /90.... they all have the same size hole
Re: Jetting? [Re: emarine01] #1354971
12/18/12 02:41 PM
12/18/12 02:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
The diameter is the same the, the angle (taper) on the back side of the hole is not According to Holley that is why they, the bigger numbered jets, flow more
Re: Jetting? [Re: Cab_Burge] #1354972
12/18/12 02:56 PM
12/18/12 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And measured, those holes in that range are larger than stamped........
Re: Jetting? [Re: Thumperdart] #1354973
12/18/12 03:20 PM
12/18/12 03:20 PM
nc
E
E
nc
Thankx guys It seems when I jet down from 90s to 88 there is very litle change - LM1- I go to 87 and go way lean, some what the same when I go to 91s
Re: Jetting? [Re: emarine01] #1354974
12/18/12 04:52 PM
12/18/12 04:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Have you fine tuned w/bleeds?
Re: Jetting? [Re: Thumperdart] #1354975
12/18/12 06:33 PM
12/18/12 06:33 PM
nc
E
E
nc
Yep... went from 31 to 29 on the HSAB after the first jetting from 88 to 90 showed no change, this make it too fat so I went down to 87s which made it too lean , the air temps were all over the place that week also so I switched to another carb that worked but was too small cfm wise its a demon 850 w/annular boosters which limits my rpm, We just stopped racing for the winter so I have some time to get it right, don't have that many HSABs to test with right now or too much experience fooling with the bleeds.
Re: Jetting? [Re: emarine01] #1354976
12/18/12 07:27 PM
12/18/12 07:27 PM
Locomotion Offline
Locomotion  Offline
Standard Holley jets have some percentage of production tolerance, but i forgot what it is. But some may actually overlap in flow.
There are some close-tolerence jets that are available through Comp Cams and I believe Holley has some as well.
Myron
Re: Jetting? [Re: emarine01] #1354977
12/18/12 10:31 PM
12/18/12 10:31 PM
Which carb, brand, size and type, are you working on? If it is a stock Holley which List number is it with the dash number, IE List 4781-9 ?
Re: Jetting? [Re: Cab_Burge] #1354978
12/19/12 12:15 AM
12/19/12 12:15 AM
nc
E
E
nc
Its a BG race demon 1000, the best that I can tell its the same as the 850 annular I have but has down leg boosters & has +5 jets larger
Re: Jetting? [Re: emarine01] #1354979
12/19/12 02:12 AM
12/19/12 02:12 AM
I would want to try #88 jets with a #30 HSAB. You really need to keep in mind when the weather is changing it is almost impossible to tune the carb. to perfection due to the changing temps, humidity and barometric pressure changes Humidity is a real big deal on tuning, water molicules really spread the oxygen molicules out, as you know water don't burn worth a hoot , even in alcholol I haven't play with any of the B.G. King Demons to speak of so I'm not much help, sorry
Re: Jetting? [Re: Cab_Burge] #1354980
12/19/12 06:33 PM
12/19/12 06:33 PM
nc
E
E
nc
Thakx Cab that sounds about right.... I am waiting on the air bleeds to show up, I used a friends LM1 and learned a lot, we will hunt down a LM1 or 2 @ this point.... I dont know how I got this far without one
Re: Jetting? [Re: emarine01] #1354981
12/19/12 06:45 PM
12/19/12 06:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would even go as small as .026`s or 28`s on the high speed bleeds............
