How to get 10.90s pump gas 440 in a 'cuda #1354745
12/18/12 04:54 AM
12/18/12 04:54 AM
junction city oregon
V
viperblue72 Offline OP
V
Hi guys. I haven't posted here in a while. I have a '72 cuda. So far I have put a 4.10 dana in place and 440 drivetrain. I plan to use alot of what I already have which is a fresh 440 crank, and source heads.
I am thinking some 0 deck flat tops for pump gas, have the source heads fully ported, and run a solid or solid roller. Also an at with 3500-4k stall.
I do plan to run fiberglass hood and bumpers but otherwise full body and interior (3400 pounds?)
With this stuff listed is 10.90s possible? HOw would you do it or what would you change?
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354746
12/18/12 09:18 AM
12/18/12 09:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Probably get there w/ a 10.5:1, 590 solid mech or roller cam, those heads will need some port work, 2" headers, M1 intake, 950HP carb... 3500 might not be enough stall. That should be pretty close. I thought those E-body's were heavier than that???
Coming soon!!!!
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354747
12/18/12 09:55 AM
12/18/12 09:55 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Not likely on pump gas...We always did it with 12.5:1 and a 1050 carb 440 +.03. You need +600hp. You will need to get the heads as good as you can. The convertor and cam will be critical in achieving your goal. Get the heads done first, then get the convertor and then the cam. Get the car on a diet if you can. Not easy to do, and that is why you see the need for the strokers.
Honestly, I would go with EZ1 heads with the 2.19 valves and at least a 9" 4800 convertor and as much compression as you can tolerate. A stroker with the same combo will net you low 10's...And depending on your tire, a 4.56 gear will really help and is almost required. I just switched out 4.10's in my Dana for 4.56, and what a difference. You going to need to watch the details, but it can be done, but it will take a little sorting out.
Either that, or throw away the 440 and install a Hemi. They make a heavy car run...We got 11.0's out of a 3800lb B body in street trim on pump gas! Drive it to work any day you want...
Here is my E-body off the trailer running a 6.90 with a 1.56 60ft on pump..Then I burnt a rod bearing. Good for 10.90's no problem, with a Hemi.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354748
12/18/12 10:02 AM
12/18/12 10:02 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Probably more around 3700.
Chris from New Jersey
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: fig426] #1354749
12/18/12 10:26 AM
12/18/12 10:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You DON'T need 12.5:1 and you DON'T need a Hemi to run 10.90's. Plenty of guys in big heavy B-Bodys running those number w/ old school 590 solid cams and low-buck 440's. I'd probably run a newer grind or a solid roller. I'm running a 588 comp cams solid roller. I'm guessing it cold run 10.90's if I made a few changes, like swapping my 1 3/4" headers for 2" pulling the factory 6-pack for a M1 and 1050 DOM, adding cal-tracs and jumping from a 3800 to 4200 and changing my 3.91's to 4.30's but I drive it to and from the track, and all over so I like it the way it is. I will be adding the headers this winter so we shall see how much that helps.
If you are worried about compresion you can always run a $300 snow performace meth/water injection kit... it works!
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Mr.Yuck] #1354750
12/18/12 10:28 AM
12/18/12 10:28 AM
gregsdart Offline
gregsdart  Offline
I don't know the elevation where you live, but if it isn't too high, then I agree with the combo above. You might make it with just a good valve job on those heads. Converter is going to be key, and run the cam way advanced. I have seen that basic combo with .045 in the hole flat tops go 10.80s at 3800 lbs. The converter was a 5000 plus stall though.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354751
12/18/12 10:41 AM
12/18/12 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need about 490 hp so gear, conv and a good
induction
system... chassis have to work also
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: gregsdart] #1354752
12/18/12 10:43 AM
12/18/12 10:43 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Greg's got it.
10.90's is 6.90's in the 1/8th...I did that with an iron head 451 in a Duster with 3.91's on pump gas.
On those stealth heads talk to my boy Hollis Page at hpengines.net
WIZE
In Car:
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Mr.Yuck] #1354753
12/18/12 11:01 AM
12/18/12 11:01 AM
Some days you really irk me. Do you have any 10 sec time slips with your 440? We have a guy running one in a very well set-up street legal B-body car with factory heads in the 10.70's. It ran 6.49 in the 1/8th!..Back in the day, all we had were factory heads, and that's what we made run 10.90's...Now a days the heads are x10's better, but you still have to get that weight going. 3400lbs and then the driver is not light. So you still need some gear to match the tires & convertor, and good induction and a well tuned chassis. And no you don't need a Hemi, but with no tuning, right off the trailer, I am in the 10's...YOU?
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Dragula] #1354754
12/18/12 11:08 AM
12/18/12 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Dragula] #1354755
12/18/12 11:10 AM
12/18/12 11:10 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
My '68 RR runs 10.46 best at sea level with 505" pump gas (91 octane), Dwayne Porter MW ported Indy EZ heads cam is around .672 roller, 10.5 /1 comp, 1050 dominator carb, 4.10 dana, leave at 2500 on 9" drag radials. 10.46 @ 129 in 90* heat this last September.That was with full 3" exhaust through flows to the rear axle and 2.5" over the axle and out the back. So a similar 440 should easily be high tens. Car weighs 3640# with me in it.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Dragula] #1354756
12/18/12 11:12 AM
12/18/12 11:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
No none yet, And I don't use a trailer...but I could if that is what the car was build for. I have a full int, full trim car that I drive. As mentioned probably could be in the 10's w/o too much issue. what's the problem w/ what I said? I told him he needed more convert and to port the heads...Trust me I've seen plenty of 10.90 cars and I know what it takes to get there.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Mr.Yuck] #1354757
12/18/12 11:18 AM
12/18/12 11:18 AM
V
V
I figured I would be close with 10.5 compression, fully ported heads that flow 300+, and a [Email]255-260@050[/Email] solid roller. But maybe it's more likely Id be at low 11s. And to me 11.20's is alot different than 10.90's. Do you guys think all the above, but with 493 or 505 cubes would get me there? Greg a hemi is not in my budget, but I love your car and how it runs.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Keith Richards] #1354758
12/18/12 11:24 AM
12/18/12 11:24 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
Here is a time slip from 2009: I am in right lane see attachment.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Keith Richards] #1354759
12/18/12 11:59 AM
12/18/12 11:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes it can be done with a 440 but of course if you throw a stroker crank in and build the combo to it you can do it easier. I am very pleased so far with my combo but I do think it has more in it if I ever get around to some serious tuning at the track. I wanted my 63 to be a 10 second pump gas driver as that was what I built this last eng to do. All I wanted was to be able to drive to the track and crank out 10's running on pump gas thru the full exh and then drive home and not have to do any changes at the track. So I built a 493 using a 440 with a 4.15 crank. And I did not use alot of high dollar parts but just a few. Nothing is cheap any more.
I built a 440 shortblock using the 440Source stroker kit with the 4.15 crank that comes out to 493 cubes at .030 over. I used ARP main studs and billet steel main caps. The pistons are the 440Source dished pistons so I have 10.6 comp with the Indy EZ heads which I used. Pistons are .007 down in the hole so with the EZ closed chamber heads it has .046 quench using the Felpro .039 head gasket. Its just a basic shortblock with 24cc dished pistons. I went with the Indy EZ heads because you can still use all the stock type valve gear and headers. Dont have to use any offset rockers or special headers that the heads need with raised exh ports need. I bought my EZ heads from "Dwayne Porter" who is one of if not the best Mopar head porter there is. Also he is fair with his prices and he is a heck of a nice guy. He did some mild porting on my EZ heads and as I weighed out my options I realized the EZ heads are only a few hundred dollars more then the Eddy heads which are a few hundred more then the 440Source Stealth heads. And the EZ heads have more potential if I want to step it up in the future. My cam is a solid flat tappet speced also by Dwayne Porter for my pump gas eng. It is 264 & 270 @ .050 with .588 asnd .592 lift and is ground on a 110 LSA. I have it in on a 106 centerline. I also use Hughes 1.6 rockers that puts my lift at .632 and .628. Up top I used an Indy dual plane intake with a basic Holley 850 DP. I use a Mallory dist with the MP orange ecu. On the exh I bought the TTI 2" headers and the full 3" exh system out to the rear bumper with the X-pipe and the mufflers are Dyno-Max Ultra-Flows. This is in my 3700lb 63 Plymouth that with a Dynamic 9.5 converter and 4.30 gears with 30 x 9 tires has run 10.70's so far driving it to the track and racing thru the full exh on 92 pump gas. I can run 38 total timing all in by 1800 rpm with no ping or spark knock at all. The converter will flash about 4200 but drives like a normal converter.
Its not a simple task but its also not as hard as some make it sound. Just sit down and think out what you want and write down the combo you want and then work on it within your budget. I dont use a 1050 Dominator carb or a single plane intake or a Barry Grant fuel pump. Also I dont use MSD ign or a fuel cell........my point is you dont have to run the most exspensive high dollar parts to run like you want but you need to run the parts that will work so you can build it smartly within your budget. My 63 is a 99% street car driver that I usually drive to the track unless I race very far from home and need to make sure I have a way home if I break. If you click the link below it has alot of info about my 63 and at the bottom of the page is info on the 493 build. I wanted a car that had the wild solid cam rump rump sound that I grew to love from the 60's but idled nice enough to be a daily driver and make good power on pump gas thru the pipes. And I wanted to do it on just the eng as I dont like using power adders and I wanted it to stay a mild enough simple build. You can do what you want as you need to sit down and figure out what you plan to build within your budget. Good luck and just ask what ever you need to know here as Moparts is full of great smart people. Ron
http://www.1962to1965mopar.ornocar.com/mmo82008.html
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: 383man] #1354760
12/18/12 12:43 PM
12/18/12 12:43 PM
Renton Washington
Triple Threat Offline
Renton Washington
440
Ported Stealths
11:1
[Email]255-265@.050[/Email] Solid or roller
Good single plane M1, Strip Dominator etc
850 or 1000 holley or Dominator
4-5000 stall
4.10 gear
28" tire
If you can't go easy 10's with that stuff at 3500# you're doing something wrong. I did it at that weight with 50 less cubes.
You have a good start with the parts you already have. I'd send the converter out to have the stall raised, that's the only change I suggest.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Triple Threat] #1354761
12/18/12 01:55 PM
12/18/12 01:55 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I agree with the above statement, my car is 440, lighter than yours and 12.5.1 comp. I still think my car would go 10.30's with 10.5.1. Put that in a heavy car like yours, easy 10.80-90.
I use an ultimate converter 5000 stall.
You may not do it first time out but once you've got it dialled in, 10's should be attainable, assuming the chassis is up to it.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: deaks] #1354762
12/18/12 02:55 PM
12/18/12 02:55 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
My 68 Road Runner weighs 3385# without driver..
Old school 440 shortblock..11.5 trw's-6pak rods-stock crank..
eddy heads w/stage11 port by Nick at compu-flow..
600ish flat tappet comp cam specked by Nick..
M1 strip dominator intake with a 1050 carb..
hooker 2" headers thru 3-1/2" flow masters..
9" dynamic convertor (4500 stahl)..
727 trans..
4.10 8 3/4 rear..
s.s. springs..
11 X 29 slicks..
Runs 10.90'S and 6.90'S
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Gary Robbins] #1354763
12/18/12 03:43 PM
12/18/12 03:43 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
727 trans..
4.10 8 3/4 rear..
s.s. springs..
11 X 29 slicks..
Wouldn't those trw pistons only net about 9.8:1 compression with 84 cc heads and a .020 head gasket? A .038 head gasket would make it around 9.43:1 or so. Did you mill the block and heads?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Dragula] #1354764
12/18/12 04:06 PM
12/18/12 04:06 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Me thinks the Yuckster is dead on. Here's how we did it back in the mid 90's. Flat top TRW 440, 0 deck. Home ported 452 heads, .590 MP stick, M-1 Single plane, 850, iron rockers, 9" J converter and a 4.30 gear. On 9 x 30 slicks, through the muffs it went 10.90's until it was wore out. Best of 10.82 in good air. The car it was in? A very stock (frame tied, moly cage, no back seat, OE bucket seats, TA hood but all steel, OE windows...very streetable) 71 Challenger.
The same car, with STOCK 906 heads, a Stock Elim cam (not going to drive that on the street) and a 6-bbl went 11.20's. Changed to a 8" "race" converter and it ran 11.0s.
Car was "in excess" of 3400 lbs, too.
