Page 15 of 180 1 2 13 14 15 16 17 179 180
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353466
01/16/13 03:45 AM
01/16/13 03:45 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Are you using aluminium cables to replace battery cables & any other heavy wiring?
Re: Real world weight loss program and it` cost.......... [Re: nz383man] #1353467
01/16/13 10:03 AM
01/16/13 10:03 AM
fullmetaljacket Offline
No, only because I have not been convinced that aluminum cable could carry the current needed to start the engine and keep all things going with the battery in the trunk.
ThumperDart has looked into some type of Copper coated 2 gauge aluminum cable that supposedly works, but I have not heard enough feedback to justify it.
The bulkhead connection was interestingly mentioned that could make a smaller/lighter gauge cable work.
Anyone want to add a comment to that?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353468
01/16/13 11:23 AM
01/16/13 11:23 AM
Out West
408strokerdart Offline
Out West
I'm using the Accel "Lightening Cable" and it works great with the trunk mount battery. I have also optimized my wiring size for every wire in my car. I am even using the thin jacketed wire as well. You would be surprised how many people could get by with 18 and 20 GA wires where most "race" car wiring kits provide 14 and 16 GA wiring for everything. I think I have 20 GA going to the rear (at least 14') to power the LED tail lights. Anyway, you definately have to think outside the box when looking for places to loose weight. And no, none of it comes cheaply after the big hitters are gone.
Re: Real world weight loss program and it` cost.......... [Re: 408strokerdart] #1353469
01/16/13 02:25 PM
01/16/13 02:25 PM
408
Okay, I'm gonna look deeply into those Accel cables that you and others have mentioned.
My setup is a street/strip car and I still have headlights, Taillights, electric fan, MSD 6AL ignition, Aeromotive A-1000 electric fuel pump in the tank and that's about it.
408. Do you have your main hot lead battery cable connected at a bulkhead box on the firewall and going to the battery out back?
* And if so, does that cable continue after the bulk head as a second piece to the starter?
* What gauge is the main hot lead cable leading back to the battery?
I'm not an electrical kind of guy since the Third rail zapped me quite a few years back. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353470
01/16/13 03:44 PM
01/16/13 03:44 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I work around the power industry & aluminium cables are used widly in this industry & I believe some of the import boys are getting into it as well. There is plenty of info on the net to convert the power capability between copper and aluminium cables so you can work out what size you need.
You need to talk to someone in the industry that uses aluminium cables to get all the tricks & traps but I do know you have to clean the aluminium strands with flux & a SS wire brush right before you crimp the ends to minimise oxidation.
You are on a mission man, I wish you well.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353471
01/16/13 06:04 PM
01/16/13 06:04 PM
Out West
Out West
2GA from the trunk to a power distribution lug on my ignition panel (about where the arm rest is on the pass side). I do have another 2GA cable that goes from there to the 250A starter solenoid and then from there to the starter. I know some people frown on this style of wiring a starter, but it has never let me down. Looks clean and was the low weight solution.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353472
01/16/13 06:54 PM
01/16/13 06:54 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
This is such a cool thread.
Lee what gauge/thickness aluminum did you use for the cross brace in front of the rad?
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Real world weight loss program and it` cost.......... [Re: gregsrt] #1353473
01/16/13 07:42 PM
01/16/13 07:42 PM
I used 20 gauge which on some gauge tools read as .0375 which is similar to what the factory used on their 64' AFX cars.
You probably can not see it clearly on those black and white photos of mine, but just remember that once you introduce a bend or a edge to any flat stock sheet metal, it work hardens and becomes stronger. This is especially beneficial when working with thin gauge aluminum.
Besides that Grille cross brace, the vertical braces and stone guard underneath are also Aluminum. The hood latch/levers and other misc stuff are no longer needed because the hood pins take care of that.
Shaved a total of 14 lbs on the very front.
Re: Real world weight loss program and it` cost.......... [Re: 408strokerdart] #1353474
01/16/13 07:50 PM
01/16/13 07:50 PM
Ignition lug must be mounted on the floor by the passenger armrest I guess?
250A starter solenoid on the firewall? With that I guess you are bypassing the stock firewall mounted solenoid?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353475
01/16/13 08:00 PM
01/16/13 08:00 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Perfect, thanks.
Re: Real world weight loss program and it` cost.......... [Re: nz383man] #1353476
01/16/13 08:56 PM
01/16/13 08:56 PM
Thanks, yeah like if the import guys needed to get rid of weight. LOL.
I'll look into this copper VS Aluminum and the gauge that it ends up being. I think like what 408 said on here 2A is probably what I would need if I go that route. I'd just like to keep my ignition solenoids/relays in their stock positions and look.
After all, this is a STOCK street car. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353477
01/16/13 09:42 PM
01/16/13 09:42 PM
State of confusion
Thumperdart Offline OP
State of confusion
I went w/a # 1 and it was a LOT lighter than the cobbled up welding junk I had and I`d rather be safe than sorry..........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353478
01/16/13 10:15 PM
01/16/13 10:15 PM
#1 from the Accel line up?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353479
01/16/13 10:51 PM
01/16/13 10:51 PM
State of confusion
State of confusion
No, just the old fashioned copper............I try to get as much as I can locally.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353480
01/16/13 10:58 PM
01/16/13 10:58 PM
Rear mounted Braile battery (21) LBS and welding cable.
The battery tray is Aluminum and mounted with long high strength carriage head bolts that go through the chassis. two of them are underneath the battery.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353481
01/17/13 01:02 AM
01/17/13 01:02 AM
If I get a moment, once I get through showing some of the Meat and Potatoes stuff that got the face lift or the boot, I'll post the real micro stuff that can't be seen for hoots.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353482
01/17/13 07:35 AM
01/17/13 07:35 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I can see another pound in that battery hold down and mounts.
Doug
Re: Real world weight loss program and it` cost.......... [Re: dvw] #1353483
01/18/13 03:26 PM
01/18/13 03:26 PM
If I can't take it out of the battery tray, I'll find some where else. These Muffler hangers save 1-1/2 lbs for the pair.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353484
01/18/13 03:29 PM
01/18/13 03:29 PM
Close up of the Hangers.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353485
01/18/13 03:33 PM
01/18/13 03:33 PM
Here are some of the earliest of the Aluminum hinges that I plucked up.
They save 7 LBS total (not counting the bolts)for both doors. But... Can be costly from what I hear. $700 beans these days. Also, I believe that your doors need to be rather light in order for these hinges to have a long service life.
