Re: Ladder bars on A body
[Re: Wedgeman]
#1352709
12/16/12 08:17 PM
12/16/12 08:17 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Just wondering what lenght did you go with? 32" or 36" thanks. Thinking about doing mine this winter.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Wedgeman]
#1352710
12/16/12 08:24 PM
12/16/12 08:24 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Anyone installed ladder bars on their A body ?
starting to install mine in my 67 Cuda....and having a little trouble with the front cross member......
Please show your pics of what you have, it will help
Dan
I don't have any pics but mine are 32in and running round tube bar and I move the wheels back 1 in and the cross member is on the frame connectors! Right at the frame rails...
[Re: Wedgeman]
#1352715
12/16/12 10:35 PM
12/16/12 10:35 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
32" on my old Duster, 32" on my old Valiant and 32's on the Barracuda. Two of the cars were 10.5 tire stofk florpans and Duster was a back half car. One set of Chassis Engineering, one set of RJ Racecars and one set of Alston Chassisworks bars.
[Re: 1967dartgt]
#1352717
12/16/12 11:51 PM
12/16/12 11:51 PM
Posts: 4,688 On the parachute mount
n20mstr
my crossmember looks like Bigtimes above.
32" ladder bars from S&W, and my car has been a string of 1.23 - 1.25 recently...hooks on ice, AND thats with a radial not a slick
Once you get them set and a good setting on your shocks, they are pretty foolproof
....BAD A$$ STREET CAR.....
[Re: Wedgeman]
#1352718
12/17/12 03:07 AM
12/17/12 03:07 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ok.... I did a trial fit of all the pieces and the front cross member will sit right under the frame connector. I will have to cut a piece of 1/8in steel with a 1 3/4 hole in it, and weld that piece to the connector with the X member trough the drilled hole
I have 32 in bars
I will post pics of the fit tomorrow, may be someone will come up with a better idea Dan
I installed 2 x 3 frame rails with the 3 inch being flat, and doing so the front ladder bar mount hit half way off of the frame rail...I cut 1/8 steel and welded it to the frame rail...did this about 4 yrs ago...using Chassisworks 32 inch ladder bars.
This is on a 71 Dart and the leaf springs were used to hold the rear end in the correct position. Also both ends of were gusseted to reinforce the 1/8 steel ..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: n20mstr]
#1352719
12/17/12 04:29 AM
12/17/12 04:29 AM
Al_Alguire
Las Vegas
I personally prefer the RJ design. Not sure there is any advantage other than possibly due to their design they are easier to get a lower rid height under as totally stock florpan.
[Re: MR_P_BODY]
#1352722
12/17/12 02:46 PM
12/17/12 02:46 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
take the eaxhaust off, PUT the crossmember where it needs to be, then fix the exhaust.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: Wedgeman]
#1352724
12/17/12 11:37 PM
12/17/12 11:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I see what you mean Mr Pbody..
Thaks for the precious info......
I will look closer at the exhaust tubes too...
For extra strength weld a piece of strap material to the front side of the brackets... then weld a tube from the strap to the frame rail... it will be on a small angle but it adds strength and in case you hit the trailer it tends to slide up the tube and not plow into the brackets
[Re: Kiddart]
#1352727
12/29/12 10:55 AM
12/29/12 10:55 AM
Posts: 9,861 MI, usa
dvw
MI, usa
I put mine right thru the subframe with a hole saw. Then cut out the bottom out slid the tube up and welded the cut out back in. The cage bar sits on a plate welded to the ladder bar mounts. Removing a section of the floor made it easy,reinstall it when done. Doug
