Re: Ladder bars on A body
[Re: Wedgeman]
#1352709
12/16/12 08:17 PM
12/16/12 08:17 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Just wondering what lenght did you go with? 32" or 36" thanks. Thinking about doing mine this winter.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Wedgeman]
#1352710
12/16/12 08:24 PM
12/16/12 08:24 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
Anyone installed ladder bars on their A body ?
starting to install mine in my 67 Cuda....and having a little trouble with the front cross member......
Please show your pics of what you have, it will help
Dan
I don't have any pics but mine are 32in and running round tube bar and I move the wheels back 1 in and the cross member is on the frame connectors! Right at the frame rails...
[Re: Wedgeman]
#1352715
12/16/12 10:35 PM
12/16/12 10:35 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
32" on my old Duster, 32" on my old Valiant and 32's on the Barracuda. Two of the cars were 10.5 tire stofk florpans and Duster was a back half car. One set of Chassis Engineering, one set of RJ Racecars and one set of Alston Chassisworks bars.
[Re: 1967dartgt]
#1352717
12/16/12 11:51 PM
12/16/12 11:51 PM
Posts: 4,677 On the parachute mount
n20mstr
my crossmember looks like Bigtimes above.
32" ladder bars from S&W, and my car has been a string of 1.23 - 1.25 recently...hooks on ice, AND thats with a radial not a slick
Once you get them set and a good setting on your shocks, they are pretty foolproof
....BAD A$$ STREET CAR.....
[Re: Wedgeman]
#1352718
12/17/12 03:07 AM
12/17/12 03:07 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ok.... I did a trial fit of all the pieces and the front cross member will sit right under the frame connector. I will have to cut a piece of 1/8in steel with a 1 3/4 hole in it, and weld that piece to the connector with the X member trough the drilled hole
I have 32 in bars
I will post pics of the fit tomorrow, may be someone will come up with a better idea Dan
I installed 2 x 3 frame rails with the 3 inch being flat, and doing so the front ladder bar mount hit half way off of the frame rail...I cut 1/8 steel and welded it to the frame rail...did this about 4 yrs ago...using Chassisworks 32 inch ladder bars.
This is on a 71 Dart and the leaf springs were used to hold the rear end in the correct position. Also both ends of were gusseted to reinforce the 1/8 steel ..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: n20mstr]
#1352719
12/17/12 04:29 AM
12/17/12 04:29 AM
Al_Alguire
Las Vegas
I personally prefer the RJ design. Not sure there is any advantage other than possibly due to their design they are easier to get a lower rid height under as totally stock florpan.
[Re: MR_P_BODY]
#1352722
12/17/12 02:46 PM
12/17/12 02:46 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
take the eaxhaust off, PUT the crossmember where it needs to be, then fix the exhaust.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: Wedgeman]
#1352724
12/17/12 11:37 PM
12/17/12 11:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I see what you mean Mr Pbody..
Thaks for the precious info......
I will look closer at the exhaust tubes too...
For extra strength weld a piece of strap material to the front side of the brackets... then weld a tube from the strap to the frame rail... it will be on a small angle but it adds strength and in case you hit the trailer it tends to slide up the tube and not plow into the brackets
[Re: Kiddart]
#1352727
12/29/12 10:55 AM
12/29/12 10:55 AM
Posts: 9,835 MI, usa
dvw
MI, usa
I put mine right thru the subframe with a hole saw. Then cut out the bottom out slid the tube up and welded the cut out back in. The cage bar sits on a plate welded to the ladder bar mounts. Removing a section of the floor made it easy,reinstall it when done. Doug
[Re: dvw]
#1352728
12/29/12 11:06 AM
12/29/12 11:06 AM
dvw
MI, usa
[Re: Wedgeman]
#1352735
12/30/12 03:07 PM
12/30/12 03:07 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
How are you supossed to change the front of the ladderbar? Looks a little bit of to me!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: Wedgeman]
#1352736
12/30/12 03:07 PM
12/30/12 03:07 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Pic of the angle
Is this all wrong ? should the holes be vertical so you can adjust the front of the bars up and down ? the way he got it. you not adjusting anything on that ?
[Re: VernMotor]
#1352739
12/30/12 04:21 PM
12/30/12 04:21 PM
MR_P_BODY
Pic of the angle
Like said here... you have it all wrong.. the front mounting holes need to be VERTICAL .... thats not what I meant by 30-40 degrees APPLIED angle
[Re: Wedgeman]
#1352741
12/30/12 06:54 PM
12/30/12 06:54 PM
VernMotor
Mt.Vernon ,Ohio
Ok I just saw my mistake...!!! got them wrong in the welding process....
First question: what is the effect of moving the bars up or down ?
Well with going in to a long response //that is how you in part adjust them.
[Re: Hemi SS]
#1352742
12/30/12 06:55 PM
12/30/12 06:55 PM
dvw
MI, usa
the bottom
Very nice dvw! Whose parts did you use?
Parts are S&W, 36" bars. As to the bracket pic above that might actually work. Think about it. Cars that like the instant center further down probably like it further forward as well. As you adjusted down it would come forward as well. There would have to be enough tire clearance at the front of the well as long as enough for the driveshaft. Would it work? I'm already trying enough off the wall stuff myself , but never say never. Here's the back of mine. Doug
[Re: dvw]
#1352743
12/30/12 07:57 PM
12/30/12 07:57 PM
bigtimeauto
Trophy Winner
Trophy Winner
the higher the bar angle the harder hit for a shorter time, lower angle less hit but longer time. Is the short version. If you have stock front suspension (at least 6" of travel)Set your ladder bar around 2* down AT RIDE Height and you will be fine.
Thats the short version, i can't type enough for all of it.
[Re: MR_P_BODY]
#1352744
12/30/12 09:23 PM
12/30/12 09:23 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Pic of the angle
Please explain, because I'm getting more and more confused here.......
[Re: Wedgeman]
#1352748
12/30/12 11:48 PM
12/30/12 11:48 PM
MR_P_BODY
Like Bigtime shows is correct... being that the axle centerline is 16" and the front is 12" is ok BUT the ladder bars are lower than the center of the axle... if you set the pinion at zero then measure the drop to the lower bar you will see its lower... you want the bar to angle down in front about 5* on the bottom hole.. that way you can always raise it up... the problem most guys have is they cant get the front of the bar low enough Here is a pic of mine before I put the support bar on the front of it
[Re: Wedgeman]
#1352749
12/30/12 11:59 PM
12/30/12 11:59 PM
dartman366
Mt. Vernon, Ohio
is the rear axel set at the ride height that you want?? if not then thats the first thing you need to set, then set the ladder bars level to the car and then use the center hole of the front bracket with the holes in a vertical position, you will need to attach the crossmember at that point,,my first attempt at this was with a round tube crossmember and it actually hung below the subframe connector, worked that way for years untill I went to a dana and from 32" bars to 36" S@W's and lowered the car somewhat,I then went to a 2X3 front crossmember with 5 adjusting holes.
[Re: dartman366]
#1352750
12/31/12 12:47 AM
12/31/12 12:47 AM
Wedgeman
is the rear axel set at the ride height that you want?? if not then thats the first thing you need to set, then set the ladder bars level to the car and then use the center hole of the front bracket with the holes in a vertical position, you will need to attach the crossmember at that point,,my first attempt at this was with a round tube crossmember and it actually hung below the subframe connector, worked that way for years untill I went to a dana and from 32" bars to 36" [Email]S@W's[/Email] and lowered the car somewhat,I then went to a 2X3 front crossmember with 5 adjusting holes.
Yes the axle is set at ride height, and the bar is leveled to the car.....
[Re: Wedgeman]
#1352751
12/31/12 12:59 AM
12/31/12 12:59 AM
MR_P_BODY
In what hole... you always want to be able to get it down in the front... higher the HP the lower the front of the bar tends to be
[Re: Wedgeman]
#1352752
12/31/12 01:16 PM
12/31/12 01:16 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
This may make me an A$$ O but stop what you are doing and get some help locally. The advice you have been given so far is spot on but you don’t seem to understand what the ladder bars are trying do much less the physics involved. I know we all have to learn some time but this is one you need hands on advice. By today’s standards it is taboo to cut and splice the cross member (especially to clear an exhaust) the ramification of you efforts so far are going to cost you additional $$$ and potentially harm yourself, your car or others. I do appreciate your desire to do it yourself and aplaud your initiative. But get some local help and do it right.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1352753
12/31/12 01:43 PM
12/31/12 01:43 PM
dartman366
Mt. Vernon, Ohio
I have been watching this post and I have to agree with you,,,while I applaud the op's intentions to do things on hs own I will have to say it's one thing to read a post on a forum than have someone with prior experience give a helping hand in sorting it all out,,,too bad I dont live closer as I would love to help out and get it as right as I know how, if nothing else than to save a lot of aggrivation in the future.
[Re: dartman366]
#1352754
12/31/12 05:53 PM
12/31/12 05:53 PM
MR_P_BODY
I think I'm gonna have to agree here... the way he has cut the front cross bar he has increases the leverage arm on the mounting points at the frame rails... you have to deal with the chassis FIRST then you worry about little things like the exhaust... NEVER sacrifice the rigidity of the chassis due to unneeded leverages that are in a bad way... some things the leverage helps but not in the places he has it
