Re: TIMING QUESTION
[Re: hemi-itis]
#1351816
12/19/12 12:25 AM
12/19/12 12:25 AM
Posts: 4,675 On the parachute mount
n20mstr
BTW,,,,,,,the straps were in the oil pan
ok...now i see, you ned to really strain the oil to keep the straps out of the bearing area...
....BAD A$$ STREET CAR.....
Re: TIMING QUESTION
[Re: n20mstr]
#1351817
12/19/12 12:32 AM
12/19/12 12:32 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Exception to the rule is when said strap enters through the top of piston.I thing they evaporate similar to a meteorite entering the atmosphere.So you would really have to sift through all the remnants in the oil pan
Re: TIMING QUESTION
[Re: hemi-itis]
#1351820
12/20/12 01:14 AM
12/20/12 01:14 AM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
Detonating that bad makes for extreme cylinder temps. The straps melted away like solder.
Re: TIMING QUESTION
[Re: WheelsUp73]
#1351821
12/20/12 01:34 AM
12/20/12 01:34 AM
hemi-itis
They go POOOOOOOf,just like all his threads
Re: TIMING QUESTION
[Re: WheelsUp73]
#1351823
12/21/12 04:21 AM
12/21/12 04:21 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Not to mention so does the head gasket and the top of the block.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: TIMING QUESTION
[Re: Evil Spirit]
#1351824
12/21/12 10:33 AM
12/21/12 10:33 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
We have run 80 to 85, but seem that the straps on the plugs are going, plus theres holes in the pistions so we duck taped the holes, and backed the timing down to 70 to 75, seems to be god there, but it starts hard(locked out) so we put a timimg retard on it, now I can't seem to get it to stop kicking back ? I'm not sure what to do now
Re: TIMING QUESTION
[Re: 70dusterjohn]
#1351825
12/21/12 12:32 PM
12/21/12 12:32 PM
Posts: 3,695 nc
emarine01
nc
Time for a air starter
Re: TIMING QUESTION
[Re: emarine01]
#1351827
12/22/12 11:18 AM
12/22/12 11:18 AM
hemi-itis
I understand.................Air head,uses air starter
Re: TIMING QUESTION
[Re: n20mstr]
#1351829
12/22/12 04:36 PM
12/22/12 04:36 PM
Posts: 2,379 MD
Kevins493
MD
Well a full load (nitro) usually likes at least 50* of lead. I would start there and work up..
Ok so with NO NITRO.....70* is good?
750* would work best!
Re: TIMING QUESTION
[Re: Kevins493]
#1351830
12/22/12 11:39 PM
12/22/12 11:39 PM
n20mstr
you know, today the temps are about 30 35 here and i tried starting my car....it was like rrrrrr rrrrrr rrrrr DO you think the Nitro70 oil and the 70* timing are hindering the "cold startability" ???? Should i be heating the oil ?
Re: TIMING QUESTION
[Re: n20mstr]
#1351832
12/23/12 02:13 AM
12/23/12 02:13 AM
Posts: 2,379 MD
Kevins493
MD
Mix nitromethane and hydrazine with the oil to thin it before starting. Also continue to advance the timing until it does not kick back. Then advance it some more until it actually fires.
