Re: LA heads on Magnum Block???
[Re: DakFink]
#1351711
12/15/12 04:08 PM
12/15/12 04:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thinking of Putting LA style heads on a Magnum Block. (Airwolf 220s)
I know the Magnum Block can be drilled for Shaft oiling.
BUT would push-rod oiling be better or just as good?
Who makes new shaft rocker set-up for LA heads? Preferably in 1.7:1 ratio.
Do the rockers need anything special for PushRod oiling???
I use TD rockers...the one thing you need to make sure of is that a oil through PR rocker has the oil hole in the cup to push oil to the rest of it... some rockers that shaft oil have a hole that points towards the cup so that wouldnt work with PR oiling
[Re: MR_P_BODY]
#1351712
12/15/12 04:15 PM
12/15/12 04:15 PM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Thanks Mr P Body!!
I was hoping to find something a little cheaper than the T&Ds. Got those for my W9RP heads and know they can also be had with through arm oiling to the valve stem.
Trying to get a BEST BANG for the BUCK on this engine and not go overboard. Already did that with another engine I have.
If that's the Only real option I may reconsider another head Option I was contemplating because that drives the price close to what I was quoted for the other heads.
[Re: DakFink]
#1351713
12/15/12 04:33 PM
12/15/12 04:33 PM
MR_P_BODY
Thanks Mr P Body!! I was hoping to find something a little cheaper than the T&Ds. Got those for my W9RP heads and know they can also be had with through arm oiling to the valve stem. Trying to get a BEST BANG for the BUCK on this engine and not go overboard. Already did that with another engine I have. If that's the Only real option I may reconsider another head Option I was contemplating because that drives the price close to what I was quoted for the other heads.
There may be other companies as well but just make sure it has the hole(in pic)
[Re: DakFink]
#1351715
12/16/12 12:38 PM
12/16/12 12:38 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Manton makes the rocker arm adjusters for pushrod oiling, use AMC style lifters are they are also designed for pushrod oiling.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1351717
12/16/12 01:43 PM
12/16/12 01:43 PM
MR_P_BODY
Just by changing to a oil through type adjuster doesnt mean it will work... the rocker has to have the holes in it to move the oil to the other areas... alot of the shaft style rockers have a hole thats under the rocker arm that squirts towards the cup area... if you have that type you would need to change that or it wont work
[Re: cheapracer]
#1351719
12/16/12 03:22 PM
12/16/12 03:22 PM
MR_P_BODY
I was told that you could use standerd LA heads and stock rockers & shaft without doing any drilling. I was going to use a magnum block with it's roller cam & lifters in my 87 dakota because of the motor mounts issue and the LA intake is cheaper and I can run factory A/C and all the brackets. Also if I do the cov. what push rods I use?
Push rods will be determined by the springs... if you have strong springs and high ratio rockers you need bigger PRs... at least wall thickness or diameter... larger diameter is lighter with equal strength... so when you figure out what you will run then talk to the PR company
[Re: cheapracer]
#1351721
12/16/12 03:33 PM
12/16/12 03:33 PM
MR_P_BODY
It is stock springs and rockers. It is going to be a daly driver. The v6 has no power and gets crappy milage, the v8's did better in a small truck.
Yeah being a V6 you had to press on the pedal alot more to get them going.... if its on the E-way most of the time they could get better mileage if you kept the speed lower but at 75-80 it has to much frontal area
[Re: cheapracer]
#1351724
12/16/12 04:16 PM
12/16/12 04:16 PM
MR_P_BODY
If your block is drilled like a old style(early mag blocks) no you dont need any of it.. but if you dont have the hole for oiling then use PR oiling BUT you need the proper rocker set up
