no box class #1351700
12/15/12 03:25 PM
12/15/12 03:25 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
im thinking about making my box easy to remove so I can run two classes.. dose any body here leave off a trans brake with less than 3000 rpm.. im about 060/070 red leaving off the bottom blub at 3000 with no box.. would leaving at a lower rpm help me .. one guy I know leaves the line on a two step 1800rpm and a line lock.. is this some thing that might help me slow down the reaction time
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: no box class [Re: WHITEDART] #1351701
12/15/12 03:26 PM
12/15/12 03:26 PM
Renton Washington
Triple Threat Offline
Renton Washington
That's pretty low, I would worry about inconsistency. Can you put a taller front tire on it?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: no box class [Re: WHITEDART] #1351702
12/15/12 04:25 PM
12/15/12 04:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was racing both box and no box... I used a Biondo
adjustable button... either set it up so the button
is right for no box and the bottom bulb and adjust the
delay box to leave the button as is OR set the button
back to zero on the box(I left the button alone and
set the box to accommodate the button)... I could have
my box out in about 30 seconds.. unplug the box and
plug in a jumper then I had 2 switches I had to flip
to change the ground
Re: no box class [Re: Triple Threat] #1351703
12/15/12 04:25 PM
12/15/12 04:25 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
why not just footbrake in no-box class???
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
