Air needle scaler used to remove undercoating WOW! #1351444
12/14/12 09:44 PM
12/14/12 09:44 PM
Granite City IL.
Jimster70 Offline OP
Granite City IL.
I just used an air needle scaler to remove undercoating and years of hardened road grime on my frames and pans. Wow that is a great tool. I bought the mini scaler and it will remove a 1 foot square section of undercoating in about a minute. Just thought I would pass it along.
Re: Air needle scaler used to remove undercoating WOW! [Re: Jimster70] #1351445
12/14/12 10:04 PM
12/14/12 10:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes they will but they also do a job at texturing your sheet metal finish as well. Have you tried a steam cleaner?
Re: Air needle scaler used to remove undercoating WOW! [Re: Jimster70] #1351446
12/14/12 10:05 PM
12/14/12 10:05 PM
ALBERTA CANADA
furydave Offline
furydave  Offline
ALBERTA CANADA
They work amazing i felt the same way after i discovered one. I had to tell the world!!! No more torch and scraper
Re: Air needle scaler used to remove undercoating WOW! [Re: ScottSmith_Harms] #1351447
12/14/12 10:45 PM
12/14/12 10:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Look here, but I'm sure a needle scaler works too(works well?, just be careful with it) expecially if your car is not on a rotissierie.
web page
Re: Air needle scaler used to remove undercoating WOW! [Re: ScottSmith_Harms] #1351448
12/17/12 02:10 AM
12/17/12 02:10 AM
Granite City IL.
Granite City IL.
You can rent these steam cleaners? I saw the pics that looks like alot less work.
Re: Air needle scaler used to remove undercoating WOW! [Re: Jimster70] #1351449
12/17/12 03:27 AM
12/17/12 03:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes you can rent one at most any large rental yard. Rent one in the 1,500-2,000 psi range with temps around 200 degrees and you'll be set.
Re: Air needle scaler used to remove undercoating WOW! [Re: ScottSmith_Harms] #1351450
12/17/12 10:48 AM
12/17/12 10:48 AM
K
kielbasa Offline
kielbasa  Offline
K
INDEED! I have also seen the light with this tool. I needed to remove scale, surface rust, dirt, etc. in the little nooks and crannies of the fenderwell on my cuda.
I didn't want the mess associated with sandblasting.
I was warned not to use these around sheetmetal, and I could see that if you are a butcher - but with a careful hand and using finesse this tool is awesome. I also had a spare set of needles to play with - new sharp, square edged needles do leave divets, but rounding the needles off on a grinder helps with that.
Wear ear protection though - very noisy!
Here is the area that was repainted - perfect tool for getting the crap out of the crevices.
