Re: Anyone Get A N/A R5/P7 Combo To Run 8's Yet????
[Re: Sb Valiant]
#1351415
12/14/12 09:17 PM
12/14/12 09:17 PM
Posts: 1,532 off the grid
340B5
off the grid
Slightly off topic, but; how small in cubic inch on the W8/W9?
Yeah, it's got a smallblock.
[Re: 340B5]
#1351416
12/14/12 10:00 PM
12/14/12 10:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Hopefully I will be able to answer that soon. I have 358 R5P7.
I think with the powerglide it will be really hard. Have been comparing dyno sheets. The engine I bought was oversold a little. I am going to lose 30 lbs of torque. Gain 5 HP with Q16. That is if the extra compression does not help. I really think the extra 1.2 in compression should pick up the torque to over 600 lbs.
My old W8 421 ran 8.90 and had over 880 HP from 8,000- 9,000. On paper it should have really carried the mail. The car MPH'ed really well but would not 60 or 330 with the powerglide with any gear ratio and several converters. It was kind of nutty. It would not leave but 20 ft out tried to blow the tires off. Had to take 2-3 degrees out around the 7600-7,900 RPM range in low gear to keep things in control. For the most part just think their was a serious problem with the combination.
An engine with that power should run 8.5's in my car. So we will see what the R5P7 does. Just not extremely optimistic.
Leon
[Re: dizuster]
#1351418
12/14/12 10:19 PM
12/14/12 10:19 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Has anyone put a Liberty behind one of these yet to use the powerband to its true potential, like a baby pro stock car, yet?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: dizuster]
#1351419
12/14/12 10:32 PM
12/14/12 10:32 PM
Posts: 41 PA
R5P7 Bantam
PA
Guys, Take this for what it's worth, but my experience with these motors is very similar to how high torque BB "bracket" cars (typically dragsters) are set up. I'm refering to how they tighten up the convertor to leave "soft" hence not hitting the tire too hard. Then out 30' its really digging in and and comes on like a freight train.
Now, with the 358, you need to have a loose convertor ~7500. Trust me, any tighter and the performance falls off by tenths. Been there, done it. Once figured out, the convertor only lasted ~85 passes and needed a rebuild. It also wasn't the most efficient, but made the car perform the best. Talking on the order of 10% slippage, but boy could it repeat itself. Where I'm going with this is, you can't go after the "hit" trying to get all the torque you can to move your car. Let it come to the car by 20', it will help with 60' times on a little tire and the HP will get you rolling.
Once last thing, it you have the original ring pack 1.5mm or .031" in it, with .007-8" piston to wall clearance, you gotta run it hot! I can't stress that enough. If you run it cold <180F, you'll loose a tenth again. Ask me how I know.
Good luck, they're great to race with and the technology is just cool.
Regards, Mike
[Re: dizuster]
#1351420
12/15/12 01:02 AM
12/15/12 01:02 AM
Leon441
Lynchburg, VA
Tim didn't seem to have an issue with his Daytona running. In Hot Street there was a 2800 minimum. I just can't see 150 lbs. making that much difference. My issues were with the 60 and 330 times. Otherwise the incrementals were respectful. Bill's car was just over 3,000 and ran a torqueflite. Chris ran a similar combination with his green barracuda with a torqueflite and just could not get around these issues either. Like I say can't see 150-200 lbs making the difference. Tim had something else going on besides a sleeker lighter car. Pro Trans anyone with an A-1 converter. Palini ran great with one of these engines too with weight. Tim's brother Mike ran well with the Demon and a powerglide and had less head than any of the others mentioned, Tim's words not mine. But, he ran 8.80's with more weight, less tire and a powerglide. So it can be done. Just got to get the combination right. I suspect my 7" converter was similar to what Mike ran as Tim recommended it. My car just tore the things up.
I think the small tire is a freind to these engines in heavier cars. My problems were weight, two speed tranny, too much tire. Something has to give. Some wheel speed, more gear ratio's to stay in powerband, less weight to not bogg on the converter.
Like I posted my old W8 was making 880 HP at 7,800 and that is were the car started spinning. But, put bite in the car and it would hook too quick. This P7 only makes 850 at 7,800 and brings the power in more gently. This should allow me to take bite out of the car and still not blow the tires 30 ft out. Although the converter guys would never agree I really think a 6,500 converter will work better when running a glide. I ran one with the W8 and the car was faster in the short times. But, everyone thought that was the wrong way to go and I listened. The converter I have now stalled 7,200 with the W8 and this R5P7 engine will make far less torque at that RPM so the converter should stall less. Just how much, don't know. But, I am planning to try it first.
Leon
[Re: Leon441]
#1351421
12/15/12 12:02 PM
12/15/12 12:02 PM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
I think 8's are ultra possible. I have already seen one go 9.40 at 142+ in a 2950 pound car. This with a tiny cam and 12 to 1 compression. By tiny cam,248@50 lol Used a 904 tranny, reworked 8 inch convertor and was able to dip into the high 1.2xx 60 foots.Think he shifted it under 8k. Car really seemed to get with it in second gear.Had a 950 carb on it With the big head, i think a three speed tranny is a huge plus at 358 inches.
Gotta think bigger cam and more compression should get in 8's pretty easily with a 3 speed, based on what i have seen.
[Re: B3422W5]
#1351422
12/15/12 12:29 PM
12/15/12 12:29 PM
Posts: 5,160 Texas
dannysbee
Texas
With all the new 5-8 speed auto tramsmissions out there. Why not work off on of those platforms. The the Challenger, Corvette and Mustang multi speed autos seem to be fairly durable. 6000 stall and closer gear ratios might work.
Getting old just means you were smarter than some and luckier than others.
[Re: topfueldart]
#1351423
12/15/12 12:53 PM
12/15/12 12:53 PM
Posts: 4,421 in a chair
mopartony
in a chair
I am. Bruno and Liberty. car and motor are being built now.
I do have a question about the changes made to your R5's, Leon, Bantom and if anyone knows about Tim Davis' motor he built. Is everyone running the NASCAR cast intake or did you change to the M&M intake or have a sheet metal intake made? Did you get a custom cam ground or adjust the one that the NASCAR boys are running? What compression are you running?
[Re: dannysbee]
#1351424
12/15/12 01:45 PM
12/15/12 01:45 PM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
All the 5-8 speed Automatics out there are electronic controlled.
If you think EFI can be a hassle you haven't seen anything yet. They do make standalone computers for some of the Electronics Transmissions.
BUT for the headache, hassle, complication, weight and $$$$.
Lenko, Liberty, Bruno would be the better choice.
[Re: mopartony]
#1351425
12/15/12 02:42 PM
12/15/12 02:42 PM
Posts: 41 PA
R5P7 Bantam
PA
Mopartony, When I first put the car together, I put the motor in it just as it came off the dyno at EEI. Obviously, I had to disassemble the front half of the motor and machine/make everything to fit in the frame rails, but other than that, internals remained untouched and legal for Nascar. This one is a roller combo with only .730 lift and 245 @ .050. Certainly nothing BIG in drag race terms. I also ran the cast intake and used a toilet (injection). Motor made more hp on gas, but I prefer the injection (just preference). When I first started, it left like a beast, because it was real fat. By beast, I mean 1.05 60' @ 1650lbs and only 358in and 12:1 comp. But the car didn't mph well.....162mph. Anyway, after pulling tons and tons and tons (can't emphasize this enough) of fuel away, walla, it came to life. Same combo picked up .5sec, yes 1/2 a second in et and 9+mph in the quarter. Best investment you can make is an O2 in both sides of the motor 12" down from the head. The tune was set for 90deg weather in eastern PA (humid) and ran 7.70 all summer. When everyone else dropped off tenths in the summer heat, we didn't loose .01. These motors are super efficient, and not meant to mix and match parts. I do have the first Bullet cam made for these motors, that I may try this coming year, but if it doesn't improve performance by .2 or more, I'm going back to the smaller roundy round cam........no wear and tear....they last forever. If you want to mix and match, I suggest you get some raw heads (they're cheap ~$300) and send them to Slawko or Patterson and build it from the ground up. If your intent is to take a nascar motor and change this and that and expect an additional 100+hp, that's wishful thinking. It may show that 100+ on the dyno, but it won't on the track. Just my $.02
Best speed secret out there: It doesn't take all that hp to win, you just need the rest of the combo to perform equally up to snuff. I'll leave with this question: When's the last time you pushed your car around? Can you push it with one hand or finger? There are tenths to be gained with rolling resistance.
Mike
[Re: B3422W5]
#1351426
12/15/12 03:05 PM
12/15/12 03:05 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Don, I hear what your saying in regards to the P7 deal you are talking about. However 9.40 is a LONG way from 8.99. Believe me. However I dont see why it could not be done.
in fact I am sure it can be done, I am sure it has already been done. In the PSCA class I run Hot Street it has a very large presence of these old nascar pieces. Unfortunately they are Ford and Chevy ones. Also most are a tad larger than 358, generally in the 390" range. Those cars are runniing 8.40's to 8.20's but are liteweights coming in at 2600-2700lbs. We have been discussing, as racers of maybe going to a cup based engine all around. Meaning everyone will ahve ti run these type of motors. Of course the Chevy guys are the ones leading that pursuit, as they are the fast cars. But I am not opposed to the idea. My problem is the lack of developement for the Moapr cup stuff in drag racing. I know the 2.2's are making 1000-1050 hp but they have reat support to make them drag rac friendly. I hear MBE is doing Mopar stuff but have never contacted them about goign this route. But I am certainly intrigued and interested.
[Re: Al_Alguire]
#1351427
12/15/12 03:16 PM
12/15/12 03:16 PM
B3422W5
Portage,michigan
Al
The motor I am referring to also had the liabilities of not using an electric water pump, and used straight 2 inch W2 headers that perhaps weren't optimal.. not sure what was left on the table there? Like to see what a good dominator would have done as well on it, definitely likely some 20's in that with some tweaks.
[Re: B3422W5]
#1351428
12/15/12 08:05 PM
12/15/12 08:05 PM
Leon441
Lynchburg, VA
The combo was ran with the small plenum edelbroc intake from Nascar. They tried the M&M and it did not run as well. I have a large plenum edelbroc I may try but, the powerglide will probably like the small one better.
