, Is it really necessary to ??????????????????
#1351381
12/14/12 07:30 PM
12/14/12 07:30 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Do the final hone with a plate, there was some guy's in the shop today and this discussion came up, they asked me what I thought about it, I know the last 3 engines I have done were honed with a plate, but really couldn't tell any difference et wise, than all the other 1's I have done without it, so I really couldn't make a good argument either way, so does anyone have any real concrete info either way??????????
Thanks Dave
Re: , I know thIs it really necessary to ??????????????????
[Re: 65racer]
#1351382
12/14/12 08:09 PM
12/14/12 08:09 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
It just depends on how much the block in question changes when you torque down the torque plate. Some blocks may change very little other. Others can change quite a bit. Always better to be on the safe side and use the plate.
[Re: Leon441]
#1351383
12/14/12 08:12 PM
12/14/12 08:12 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Best answer I've heard on this debate.
[Re: Leon441]
#1351385
12/14/12 08:56 PM
12/14/12 08:56 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
You don't know. Rookie
Re: , Is it really necessary to ??????????????????
[Re: Thumperdart]
#1351386
12/14/12 08:58 PM
12/14/12 08:58 PM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
Last time I had my motor out to Mike he checked the cylinder walls and said they were wavy. Had him hone it with a plate. Car picked up .001.
[Re: 65racer]
#1351387
12/14/12 09:40 PM
12/14/12 09:40 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
As already said it depends a lot on the type of block and how many head bolts hold the heads on I've seen major distortion on SB Mopars, not so much on the BB and Hemi blocks Best bet to see the results on how the plate(and the head gaskets) affect the cylinder walls is to use a dial bore gauge on the cylinders form top to bottom and all the way around the bores with nothing on the block, install and torque the main caps and check again, same thing on the plate and head gasket I use them no matter what Ring seating time and HP are different with and without them, been there, done that
[Re: Cab_Burge]
#1351388
12/14/12 09:51 PM
12/14/12 09:51 PM
Leon441
Lynchburg, VA
Also use your head studs. If you run aluminum heads. Make aluminum spacers up to simulate the height of your cylinder head. Preheating the block and warm honing oil can't be a bad thing either.
Sense we are telling all our secrets LOL
But, what do I know Josh says I'm a Rookie.
[Re: 65racer]
#1351389
12/14/12 09:54 PM
12/14/12 09:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I asked a builder I know how much deflection would be seen from using the plate to not... he said he has seen .003 distortion in spots(that was a 4" bore)
[Re: Leon441]
#1351390
12/15/12 01:31 AM
12/15/12 01:31 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Back in the old days I towed with a GMC that had a SBC engine. I had to take the heads off to fix a head gasket problem and there were shiny spots in the cylinders adjacent to every head bolt. I didn't mind seeing that truck go away at all. It looked okay but the cost-cutters must have had the last word on the design of every part.
[Re: @#$%&*!]
#1351391
12/15/12 09:48 AM
12/15/12 09:48 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Back in the 80s I looked at a Ford 302 that was in a race shop for inspection because of a warrantee lawsuit. The bores were so out of round and no sign of ring contact in huge areas next to each bolt head. I don't know how that motor made any hp, it looked that bad. And to think the guy had to go to court,,,,,,,,,,,
[Re: 65racer]
#1351392
12/15/12 12:14 PM
12/15/12 12:14 PM
Posts: 7,506 Az
Crizila
Az
Thanks Dave
IMO, if it's a seasoned block, you're splittin hairs - and that's why there isn't any concrete info on it one way or the other. The honing process itself is much more important than the torque plate.
Fastest 300
[Re: Crizila]
#1351393
12/15/12 04:06 PM
12/15/12 04:06 PM
BradH
I've seen a number of tech articles showing different levels of bore distortion w/ plate-honed and non-plate-honed blocks, as well as claims that certain honing techniques (e.g. "hot honing") resulted in HP improvements in Pro-level engine programs. However, I've never seen a true A-B test of the same engine prepped & tested w/o plates first, then re-honed w/ deck plates. That would be interesting, but not likely to be high on any tech writer's list of articles to fund.
FWIW - not much, I admit- my 452 block hasn't been plate-honed for the last two rebuilds (even though I'd been told it had been by the previous shop that took it from 4.375" to 4.380"). I don't recall the amount of OOR at the top of the bore the current machinist found when he bolted on the plate to the 452, but he said it was enough that he couldn't re-hone it w/ the plate unless I was willing to bore it out yet again. Since the block was already .060" over, I didn't have access to a sonic tester to see how thick the walls were, and it would require custom pistons for a bigger bore even if the walls were thick enough to go bigger, we agreed to just re-hone it "as is".
My build-in-progress 451 block has similar & frustrating history. A previous shop that had supposedly "race prepped" it w/ a 4.360" bore turned out to have not plate-honed that one, either, so we didn't take any chances and re-bored this one to 4.375" using a plate to do the final hone.
