Jumping the relay take a lot of things out of the circuit. When it won't start, remove the yellow wire from the "I" terminal on the relay. Hook a starter switch between the 12v source (at the relay or battery, whichever is easiest) and the "I" terminal. See if it will crank by pushing the switch. If it cranks, you have a problem between the relay and ignition switch (the ignition switch gets its 12v from the fusable link through the bulkhead and then back to the relay from the switch). If it doesn't crank, leave the starter switch in place, but remve the wire from the "G" terminal and run a jumper from the "G" terminal to ground. Try the switch again. If it cranks, you have a problem with the nuetral safety switch circuit and the most common cause of this is a mis-adjusted shifter...
