Re: Thinking About Getting a Tunnel Ram for My 440
[Re: roadhazard]
#1351083
12/14/12 01:50 PM
12/14/12 01:50 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'm gathering the parts now with two 750's Just linkage and another main body, I'm good to go
Oh if your looking for a pair of 1850's drop me a line
Greg,we probably have tops and linkage in the attic.
Bob I may just have to make a trip to the Hog Pen
Let me know if you are,I'll make a gasket order and save shipping.
[Re: Lil Demon]
#1351085
12/14/12 01:58 PM
12/14/12 01:58 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Yep, a pair of 1050's are the way to go!
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Dodgeguy101]
#1351087
12/15/12 02:06 PM
12/15/12 02:06 PM
Slingshot383
St. Charles, MO.
Almost as easy to find a standard port tunnel ram, do a heliarc aluminum build-up above the ports and port it to Max-Wedge size yourself.
[Re: ProSport]
#1351090
12/15/12 07:02 PM
12/15/12 07:02 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
That would depend on the combo. I ran two 750's on my 9 second 451" Eddy headed motor.
I forgot how much faster you went with the tunnel ram ? But didn't you end up taking it back off ? Ron
[Re: 383man]
#1351091
12/15/12 07:22 PM
12/15/12 07:22 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
I only removed it cuz I didn't care too much for the Eddy carbs, I just wasn't good at tuning them. I put it back on when I bought the 2 tunnel ram 750's from Quickfuel. The car ran in the 10.05 area with the single dominator, with a best of 9.95 in real good air. With the tunnel ram it was consistently in the 9.90's even on hot days, with a best of 9.88. The new owner has gone 9.77 with it.
Everything was better with the TR, streetability, starting the car, 60 foot, ET and MPH. Only downfall was guzzling fuel too fast and having to change all those jets but really didn't need too once dialed in.
[Re: 67Satty]
#1351093
12/15/12 08:13 PM
12/15/12 08:13 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
In late 1980's I put a tunnel ram kit on my 67 barracuda. It was from summit racing, Weiand tunnel ram with two 450 cfm Holley carbs. The engine was only a 340 with a Lunati Bracket Master hyd cam .480 lift 234 dur. but it ran great on the street and turned 12.20s at Cedar Falls Raceway down in Iowa.
Snap your neck, mega G-force launch, is all I want!
[Re: 383man]
#1351094
12/17/12 03:38 PM
12/17/12 03:38 PM
Posts: 3,746 Riverside, California
Lil Demon
Thanks for the info. So it seems the car was a good tenth faster with the tunnel ram setup and drove good. I really liked how well that combo ran. Ron
When I switched from the single Indy intake and 1050 to the Indy TR and twin 1050s - my car picked up .25 and 6 mph in the 1/4. My bullet is relatively new - I've only put a handful of passes on it and then we were sorting out shock and 4 link settings. The car went 9.41 @ 143. It repeated that number at a race, but on 9.60 index - so the advice to try and slow it down was to short shift it - engine builder said to shift it 7400, so the thought was shift to 2nd right after the launch and the hit 3rd at 6400 - car went 9.31 @ 148.899. Oops. Then I've had it parked for the past 3 years going through some personal stuff - once I bring it back out it will be fun to mess with and see what she'll really run.
[Re: SG duster]
#1351098
12/22/12 02:14 PM
12/22/12 02:14 PM
Posts: 996 Queens, New York
Harley
Queens, New York
I have been running a tunnel ram on the street for years on my 440ci and now my 505ci. As stated above they do drink fuel more than a single four. At the track the tunnel ram with 2 750’s was 2 tenths faster than the single four.
