Re: lowering compression ratio?
[Re: Slipknot440]
#1351026
12/13/12 10:47 PM
12/13/12 10:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Look at the receipts and see how he made it "13:1".
Might find that's an optimistic guess and not a measured specification. If it is indeed a fact then you ought to be able to see what was done via the receipts and can undo it. SBC heads are cheap, you could probably pull the current heads, sell them and put on a set of larger chamber heads for not much out of pocket after it's all said and done.
