street roller cam ? #1350929
12/13/12 02:17 PM
12/13/12 02:17 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i put a fairly agressive(cant remeber the exact specs)Comp roller in my RB but cant seem to get a mech.fuel pump to work on it.my ? is once you reach a certan level is there even an ecentric on the cam for a mech. pump.
Re: street roller cam ? [Re: bonefish] #1350930
12/13/12 02:21 PM
12/13/12 02:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
As I understand it most roller cams do not have the fuel pump eccentric. I'm running a small solid Comp roller (588) and it doesn't have one.
Coming soon!!!!
Re: street roller cam ? [Re: Mr.Yuck] #1350931
12/13/12 04:06 PM
12/13/12 04:06 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thanks, thats what i figgerd,my last roller,a Lunati had one.
Re: street roller cam ? [Re: bonefish] #1350932
12/13/12 04:12 PM
12/13/12 04:12 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I'm running a Lunati hyd roller and it has the eccentric for the fuel pump. I still went with an electric fuel pump thought!
Re: street roller cam ? [Re: brads70] #1350933
12/13/12 04:18 PM
12/13/12 04:18 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Good to know. I'm planning on a roller BB and was toying with the idea of going full electric. guess this helps make my decision.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: street roller cam ? [Re: VincentVega] #1350934
12/13/12 04:57 PM
12/13/12 04:57 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I have a Bullet Roller and I use a mechanical pump with it. My cam is an older blank so that may be thediference. I do know they make a special pushrod for use with Roller cams (Mancini sales it). The pushrod has a brass tip to work with the harder Roller cam (like a brass timing gear).
Old Geezer Racing
Re: street roller cam ? [Re: bonefish] #1350935
12/13/12 08:33 PM
12/13/12 08:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My Comp Cam has one.
