Re: Cylinder bore notches???????????????
[Re: MR_P_BODY]
#1350650
12/13/12 10:48 AM
12/13/12 10:48 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Might say what engine also... BB or SB
also if BB , RB or B ???
[Re: JohnRR]
#1350651
12/14/12 11:22 AM
12/14/12 11:22 AM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Sorry guy's I didn't post what I am thinking about doing, I am looking at a b engine either 400 and making a 470 with a 3.915 crank stroke 6.635 rod with the 2.200 chevy journal, or
a 383 and making a 438 with a 3.750 stroke crank, 6.760 rods with the standard 2.375 rods.
Thanks Dave
[Re: B G Racing]
#1350654
12/14/12 11:55 AM
12/14/12 11:55 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I have a couple good shots from my 517 (4.25" arm/ 2.200 rod) on my home computer, I'll try to post them up tonight. Wasn't really needed since it really cleared BETTER than and 4.15/2.375 I've ever done (that's been many!) but I do it so if I want to go bigger at some point it's already done. I also use .060" as the minimum clearance for any rotating components in proximity to one another, (and that includes rod shoulders to cam lobes on some small block apps.)....Even though I the thought that anything is actually moving around anything close to that from the crank centerline
[Re: JohnRR]
#1350655
12/14/12 12:57 PM
12/14/12 12:57 PM
Posts: 16,928 NC
440Jim
NC
You do not need bore notches for either.
With steel rods those combos shouldn't need any grinding for rod clearance at the bottom of the cylinder bores, or the oil pickup tube boss.
For a 4.150" crank in a 400 block with 2.375" steel rods, you will need some small notches. And the oil pickup tube and the block boss need to be checked. I have pictures of somebody's engine with that combo.
For a 4.250" crank in a 400 block with 2.200" steel rods, the rods should clear the bottom of the cylinders, but it is worth checking. I put them in my block during the initial build just to be sure. The oil pickup boss in the block might clear, but I put a tiny grind on mine to get the amount of clearance I felt comforable with. I have a picture of that also.
[Re: B G Racing]
#1350659
12/14/12 06:01 PM
12/14/12 06:01 PM
Streetwize
Weddington, N.C.
As Promised...Here's a shot from my Low deck 400 230 block 517/4.300" stroke with 2.200" (BBC) journal rods.
More than it needed but already clearance in case I wanted to go bigger next time...but this combo works so well it's not gonna happen.
