Look at this piston...
#1349978
12/12/12 12:13 AM
12/12/12 12:13 AM
Posts: 1,630 North Central Florida
eightlitermopar
Ok...when is the last time your project went smoothly? I got my rings on the pistons for my 318 and started puting them in. Well....Once they are in, I noticed this. WTH? Sooo....replace the piston?
Mopar or no car
Re: Look at this piston...
[Re: astjp2]
#1349980
12/12/12 04:52 AM
12/12/12 04:52 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Naw,, its only a lil 318..
I am truckless..
[Re: eightlitermopar]
#1349981
12/12/12 05:10 AM
12/12/12 05:10 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
What kind of piston-installation 'technique' do you use in order to spot this after you installed the piston? I would sand off the sharp edges and plunk it back in. Maybe switch this piston/rod-assembly with another one if the skirt is on the thrustside of the block.
[Re: 70Cuda383]
#1349983
12/12/12 09:21 AM
12/12/12 09:21 AM
eightlitermopar
Sorry for the misunderstanding. I put the new rings on, them put the piston in the block. I honestly can't tell if this is a new or old condition of the piston.
I will be replacing it.
When the motor was disassembled, there was a lot of carbon. The motor would diesel when shut off (if it was running hot).
Could dieseling cause something like this?
eight
Mopar or no car
[Re: AdamR]
#1349987
12/12/12 10:56 AM
12/12/12 10:56 AM
BigBlockMopar
The Netherlands
I would think its going to cause an imbalance.
I think you have too high expectations of a factory's balance job.
But if one might be worried about an imbalance in a bone stock engine, maybe it's a good idea to break off all the other skirts aswell to get them all the same weight again...
[Re: Mr.Yuck]
#1349990
12/12/12 12:37 PM
12/12/12 12:37 PM
Posts: 1,443 Maryland
Dads426
Maryland
I'd check piston to wall clearance. A stock cast piston doesn't like rattling around in a big hole.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Moparnut426]
#1349992
12/12/12 10:48 PM
12/12/12 10:48 PM
eightlitermopar
I have no idea how it happened... Maybe it was slightly cocked in the cylinder when I was putting it in? This is the only thing I can think of. This is my first time assembling a complete short block by myself so I know I am not a professional at this point.
I priced a new piston at anywhere between $10-20 bucks. This is what I am going to do.
eightlitermopar
Mopar or no car
#1349993
12/12/12 11:23 PM
12/12/12 11:23 PM
Challenger 1
Cincinnati, Ohio
eightlitermopar
