Flat tappet combos #1349939
12/11/12 11:45 PM
12/11/12 11:45 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
With todays oil, why do people still use these cams? If you want a streetable combo why not a hyd roller?I think you can make as much if not more with a hyd roller.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Flat tappet combos [Re: 1967dartgt] #1349940
12/11/12 11:56 PM
12/11/12 11:56 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Hydraulic or solid rollers have their own dangers. If you do a search you will find a growing number of posts and complaints about rollers disintegrating and releasing tiny needle bearings free to take the scenic route through your engine.
There's nothing wrong with a flat tappet setup as long as it's broken in properly using the proper oils/additives. And it's a good idea to run a zinc additive after break-in with every oil change.
Re: Flat tappet combos [Re: bobs66440] #1349941
12/12/12 12:00 AM
12/12/12 12:00 AM
Hilltown Pa
Hilltown Pa
Factory cars go 100,000 mi plus with no problems with hyd rollers. I have never heard of a hyd roller failing, solid yes but a hyd roller no.
Re: Flat tappet combos [Re: 1967dartgt] #1349942
12/12/12 12:04 AM
12/12/12 12:04 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
There getting real popular these days.
Re: Flat tappet combos [Re: 1967dartgt] #1349943
12/12/12 12:36 AM
12/12/12 12:36 AM
bobs66440 Offline
bobs66440  Offline
You are correct. The hydraulic rollers are much more reliable than the solids.
Re: Flat tappet combos [Re: bobs66440] #1349944
12/12/12 03:46 AM
12/12/12 03:46 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
i am unimpressed with the hyd roller i put in my 440. since then I've been searching for dyno #'s on Big block mopars with hyd rollers on the net. looks like they all start to give up around that 5800 mark give or take a few hundred rpm. that's about where mine fizzles. it runs like a bear up till that point. a set of beehive's might help it but im pretty disillusioned. it'll twist higher but its just not there. i think they're perfectly fine for some one who just want to cruise their car around. or even a low rpm stroker. i hate to give up on mine because it wasn't a cheap proposition, but it will probably be coming out this winter for a solid.. unfortunately it wont be a easy swap with my home made valley tray... got a .557 cam brand new in the box, thinking that might give it the kick im looking for.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Flat tappet combos [Re: 68 HEMI GTS] #1349945
12/12/12 04:17 AM
12/12/12 04:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One thing to remember is most stock factory cars with hyd rollers are not raced and they dont worry about valve float and lifters breaking. At least not like our hot rods. I wanted a solid cam in my 63 which is a 99% street car but I did not want to run the spring pressure I should run with a solid roller so I would not have to worry about valve float and roller lifter wear. So I went with a solid flat tappet and run much less spring press then a roller. I do know many do run solid rollers on the street and some have had lifters break and cause eng damage and some have not. I figured if I ran a roller I would want to inspect my lifters every 3000 miles or so. So I just bought a solid cam from Dwayne Porter that he Nitrided and I use the zinc additive and the Valvoline racing oil which has alot of zinc. I have had no problems at all. In fact I have never had a cam lobe wipe on me. I am not knocking rollers as I know I could make more power with one and if my car was race only I would use a roller. I just did not want the worry about the lifters coming apart in time. Ron
Re: Flat tappet combos [Re: 68 HEMI GTS] #1349946
12/13/12 04:25 PM
12/13/12 04:25 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
What are those blue rockers?
74 dart sport 440 www.Csucarbs.com
Re: Flat tappet combos [Re: shoebox] #1349947
12/13/12 04:49 PM
12/13/12 04:49 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
indys
Re: Flat tappet combos [Re: 1967dartgt] #1349948
12/13/12 04:56 PM
12/13/12 04:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
35+ years of using solid lifter cams and never hurt one yet so why change. The biggest one being a 695 lift mushroom tappet. I have hurt a couple of roller cams in the past 20+ years.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Flat tappet combos [Re: pittsburghracer] #1349949
12/13/12 07:36 PM
12/13/12 07:36 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I ran hydraulic rollers in two engines now in my scamp...Both made great power where it was SAFE, but were very RPM limited, and after two dropped valves at both 6200 and 6500 rpms, I refuse to ever use another hydraulic anything in any of my motors.
Considering how much money it is to retrofit a hydraulic roller into most small blocks and big blocks, you are better off going solid roller...or just stay flat tappet...Im going solid flat tappet, and my LA is a factory roller block! Im just tired of dealing with the b.s. that hydraulics give with rpm
Re: Flat tappet combos [Re: mshred] #1349950
12/14/12 01:28 AM
12/14/12 01:28 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Most everything I've read suggests that a solid flat tappet will outperform a hydraulic roller. I still believe that if your goal is a street/strip motor that will make good power, be trouble free and and live for years; an aggressive solid flat tappet makes a very strong argument.
Re: Flat tappet combos [Re: StealthWedge67] #1349951
12/14/12 06:40 AM
12/14/12 06:40 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
Most everything I've read suggests that a solid flat tappet will outperform a hydraulic roller. I still believe that if your goal is a street/strip motor that will be make good power, be trouble free and and live for years; an aggressive solid flat tappet makes a very strong argument.
410 pump gas solis flat tappet cam 10.95 so far
