So isn't ET ET no matter what you do to get there?
#1349839
12/11/12 11:17 PM
12/11/12 11:17 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Just a spin off on the mid 9's N/A thread.. Really, what is the difference if you run an ET N/A or with a power adder? Does it feel different? Does it look different going down the track? Those that say it is easy with a power adder have never really run a power adder to realize you can't just throw it on and go. And it is much cheaper in the long run and will certainly make it much, much more streetable.
Re: So isn't ET ET no matter what you do to get there?
[Re: TheOtherDodge]
#1349840
12/11/12 11:21 PM
12/11/12 11:21 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
As long as you don't cheat and use nitrous!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dizuster]
#1349846
12/12/12 12:22 AM
12/12/12 12:22 AM
Posts: 437 south central pa
bdaz smblk
south central pa
The thing is if running n/a was just as easy as running a power adder more people would be doing it.U don't go to a big outlaw race and see 3 or 4 different n/a classes.The best part of running n/a is when u go out and make a good pass and have people come back and look under the hood of your car and say that was all motor.If a car runs good anymore people automatically thinks it should have nos.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1349847
12/12/12 12:40 AM
12/12/12 12:40 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Thank you, James!! Somebody that has always "Got it". And really, seat of the pants, 10.20 or 9.80? it's all good!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1349848
12/12/12 12:49 AM
12/12/12 12:49 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I can leave in 2nd go a 1.40 60' and still run a 8.38 at 172 prochargers TTF!
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1349849
12/12/12 04:04 AM
12/12/12 04:04 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Makes no matter but you just need to be honest when telling about the combo. I like to know the full combo when I see or read about a car and of course if it has a power adder it makes a big difference on what you think it will run. If a car is turbo or supercharged it makes a big difference on the performance. Its like I dont think my 63 will keep up with a 528 Hemi Dart or a 360 Dart with twin turbo's on it. Ron
[Re: 383man]
#1349850
12/12/12 10:25 AM
12/12/12 10:25 AM
TheOtherDodge
Houston, Texas
After having played with N/A for a while, thinking nitrous is "cheating" I decided to try it... What I found out was that I could run a more "streetable" combination of cam, gears, compression, etc., but run a lot faster. Then I discovered boost by first playing around with a little Powerdyne on my (at the time) daily driver Dakota. Now with my turbo Dakota, I realize how a little .520/220 hydraulic flat cam with 3.55 gears, 3000 converter and 6,000 rpm shifts can run. And once I can get it to leave off some boost.... To me, if your goal is fast ET, it doesn't matter how you get there...
[Re: TheOtherDodge]
#1349851
12/12/12 10:57 AM
12/12/12 10:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
doesn't really matter how you get there. However there is a limit in what a N/A motor can run and still be streetable. For example lots of low 10-high 9 second N/A cars however I wager only a few are a real streetable car. Full Int, wipers, radio, non-big tire can drive it more than 10 miles around town, cars. Most of the driver 9 second cars are going to be boosted just becuase you can add a ton of power w/ zero effects on drivability. You can drive the car 30-40 miles to the track and roll home. Not many 9 second N/A cars are going to do that. While the initail set-up is costly, in the long run it more than pays for itself. Not sure about NO2, but I'm going to find out come spring and I'll let you know... I hoping to drop a second w/ a 150 shot and other off season upgrades...
[Re: TheOtherDodge]
#1349852
12/12/12 12:44 PM
12/12/12 12:44 PM
Posts: 20,175 Park Forest, IL
slantzilla
Park Forest, IL
WIN!/\
I get sick of people whining about nitrous. It is cheap and easy horsepower up to a point, then, just like everything else, it gets real expensive real fast.
Doesn't matter how you go fast, so long as you have fun doing it.
[Re: slantzilla]
#1349853
12/12/12 03:20 PM
12/12/12 03:20 PM
BradH
... Doesn't matter how you go fast, so long as you have fun doing it.
And you aren't cheating if there are rules involved...
[Re: TheOtherDodge]
#1349855
12/12/12 05:17 PM
12/12/12 05:17 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
It only matters to those that want to accomplish a set goal using certain parts Like me, high nines on pump gas, motor only through the muffs with the air cleaner on, street legal, full interior, 3450 lbs and very stealthy
[Re: Cab_Burge]
#1349856
12/12/12 05:25 PM
12/12/12 05:25 PM
TheOtherDodge
Houston, Texas
Cab, I bet it is a strong and nice looking ride!!!
But, with me having a power added, I bet mine is much more stealthy, especially if I have the AC running and it idling and sounding like stock!
[Re: TheOtherDodge]
#1349857
12/12/12 05:55 PM
12/12/12 05:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doesnt matter..... when you look at the time slip... does it say... turbo, spray, n/a.... nope... if you are bragging about the ET you wipout the time slip and it shows the numbers... nothing about the build
