good shock for a W200 with a 4" lift?
#1349755
12/11/12 08:37 PM
12/11/12 08:37 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Does anyone have any input on a good shock for a 73 W200 with a 4 inch lift? Its an all spring lift with no blocks, but I have really cheap gas shocks on it now and they suck. The truck is just used for general stuff, home depot, camping trips, etc. and not any really hardcore off roading. Anything to improve ride quality would be great.
Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: good shock for a W200 with a 4" lift?
[Re: blown340]
#1349757
12/11/12 09:55 PM
12/11/12 09:55 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Look into Bilstein 5125 series shocks. They are made in custom lengths and are made for lifted vehicles. You just need to know what your fully extended and collapsed lengths are, and order the shocks that most closely match those lengths. I suggest going to allshocks.com.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1349758
12/11/12 10:19 PM
12/11/12 10:19 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I see its the 200 series. Are you running a 10 ply tire (load range E)? If so at what pressure.
You may just need to drop the tire pressure down to around 45-50psi. If your running a 10 ply at full 80psi for daily driving your going to get a pounding.
On my CTD I had the fronts at 50, and rear at 45psi for daily use.
If I towed, or hauled, then I would air them up.
Another option is to get a lower ply tire. If you don't haul, or tow heavy loads, get something in a load range C rather then the E. This is what I did with my Ramcharger with the 3/4 ton axles.
A different shock isn't going to do much for ride quality on a 3/4 ton Dodge.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1349759
12/12/12 02:04 AM
12/12/12 02:04 AM
blown340
Walnut Creek, CA
Sorry, let me clarify. I'm aware a 3/4 ton truck on leaf springs with 35 inch load range E tires isn't going to ride well. However the shocks I have now haven't performed well. One of the shocks is alread acting like its blown, and even when new they didn't do a good job of damping wheel movement. I'm used to some good quality off road shocks on my jeeps, and I'm looking for something similar for the truck. I like old man emu shocks alot, but they don't offer anything for my truck, so I'm looking for other peoples input on what is a good shock for a truck like this. Thanks, -Jon
[Re: Jeremiah]
#1349761
12/26/12 09:32 PM
12/26/12 09:32 PM
Posts: 17 minnesota
royalflush
minnesota
I am sure there will be ten people that don't like them but I have been rocking Rancho 5000's on my 3/4 ton trucks with 33+ inch tires for years and they serve me well. My trucks play off road and I am cheap so it works well.
great shock! if i was to do it all again id have went with a nitrogen shock and not a gas shock. but i also offroad and haul heavy loads
[Re: blown340]
#1349764
12/28/12 11:56 PM
12/28/12 11:56 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Thanks, -Jon
What lift is on it now????
[Re: NITROUSN]
#1349765
01/16/13 01:49 AM
01/16/13 01:49 AM
blown340
Walnut Creek, CA
Thanks, -Jon
Sorry for the slow response, been busy at work. The shocks on it now are the cheapies that come with the rough country 4" all spring lift sold by Les Schwab.
I'm going to look into the Bilsteins 5100's next, although if anyone has any additional comments I'm definitely interested. I don't use the truck much in the winter so its not a big rush.
Thanks, -Jon
[Re: blown340]
#1349766
01/16/13 05:15 PM
01/16/13 05:15 PM
Posts: 169 Mount Hope, WI
694spdRT
Mount Hope, WI
I went with Skyjacker Nitros on my '76 club cab when I added a 4" lift. N8017's in the front and N8068's out back. They seem to be fine. I use it for hauling wood mainly so a great ride isn't really what I was worried about.
1969 Charger R/T 440 4 speed
1968 Charger 383 Automatic
1972 Challenger 318 Automatic
1975 W300 Adventurer Sport Factory 440 4 speed
1976 W200 Club Cab 400 automatic
1979 Ramcharger 400 automatic
2001 Durango SLT 4x4 4.7L
2005 Ram 2500 4X4 Cummins 6 speed
