413 with Dual Fours?? #1349648
12/11/12 06:22 PM
12/11/12 06:22 PM
Alberta, Canada
DRAG Offline OP
DRAG  Offline OP
Alberta, Canada
I'm looking to put a dual four barrel setup on my 65 Chrysler 300.
There are 4 different intakes to go with that were put on 413s & I'm
looking for input from past experience &/or knowledge of what what work best. If has no A/C. Intake, Carbs, exhaust? I want a setup that
looks relatively stack.
Re: 413 with Dual Fours?? [Re: DRAG] #1349649
12/11/12 06:37 PM
12/11/12 06:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
There is the edelbrock ch28 intake which works pretty well. But if your 413 is basically stock you could always go with one of the stock 413 dual quad intakes. They pop up from time to time and I think they work pretty well for a stock application.
Re: 413 with Dual Fours?? [Re: DaytonaTurbo] #1349650
12/11/12 09:16 PM
12/11/12 09:16 PM
Central NC
gch Offline
gch  Offline
Central NC
The edelbrock will likely out perform the stock one by a mile.I never liked the factory dual quad intakes but stock is stock......
Re: 413 with Dual Fours?? [Re: gch] #1349651
12/12/12 01:01 AM
12/12/12 01:01 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The edelbrock will likely out perform the stock one by a mile.{quote}
Depends on your end goal !
Depends or your end goal.
Re: 413 with Dual Fours?? [Re: DRAG] #1349652
12/12/12 09:41 AM
12/12/12 09:41 AM
Mountains of NM
65superstock Offline
Mountains of NM
Another vote for the CH28
-Jason
Re: 413 with Dual Fours?? [Re: 65superstock] #1349653
12/12/12 09:22 PM
12/12/12 09:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure if the newer carbs will bolt to the old OEM dual quads. I know the AFB changed bolt patterns at some point, not sure when though.
Don't be the exception.
Re: 413 with Dual Fours?? [Re: Supercuda] #1349654
12/12/12 09:28 PM
12/12/12 09:28 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
We used to drill the second bolt pattern in the base of AFBs. If I remember right there was plenty of space for both patterns.
I live with fear everyday but, sometimes she lets me race!
Re: 413 with Dual Fours?? [Re: Digger73] #1349655
12/12/12 10:22 PM
12/12/12 10:22 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the edelbrocks i have do have the afb bolt pattern. here's a ch28 i've played around with but never bolted it on and ran it.
Re: 413 with Dual Fours?? [Re: lewtot184] #1349656
12/12/12 11:12 PM
12/12/12 11:12 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
How old is that CH28 Lewtot? My intake has cast between the runners...Looks like you can see the valleypan on your setup
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 413 with Dual Fours?? [Re: Pyper70] #1349657
12/12/12 11:30 PM
12/12/12 11:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i did some playing around, .
Re: 413 with Dual Fours?? [Re: lewtot184] #1349658
12/13/12 12:16 AM
12/13/12 12:16 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The new pattern, but not the old IIRC. Like I said the pattern on the AFB changed at some point back in the early (?) sixties as did the airhorn diameter but I dunno if they both changed at the same time.
Re: 413 with Dual Fours?? [Re: Supercuda] #1349659
12/13/12 01:53 AM
12/13/12 01:53 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Special "K" back out after 20 years asleep
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 413 with Dual Fours?? [Re: Supercuda] #1349660
12/13/12 02:35 AM
12/13/12 02:35 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I get the smaller 4131's frequently at the swap meets. $5-$30. 4 1/8" tops.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 413 with Dual Fours?? [Re: Rug_Trucker] #1349661
12/13/12 02:47 AM
12/13/12 02:47 AM
Alberta, Canada
DRAG Offline OP
DRAG  Offline OP
Alberta, Canada
Thanks for the feedback guys! Would I need to change out the fuel pump? Do the repro air cleaners fit the edelbrock carbs?
Re: 413 with Dual Fours?? [Re: DRAG] #1349662
12/13/12 12:42 PM
12/13/12 12:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There are two different bases,the 62 early 63 used the 3447 AFB with small air horn,the mid 63 and 64 used the 3705 which has the same size air horn as the Edelbrock.
Re: 413 with Dual Fours?? [Re: 62maxwgn] #1349663
12/13/12 01:45 PM
12/13/12 01:45 PM
Alberta, Canada
DRAG Offline OP
DRAG  Offline OP
Alberta, Canada
Any recommendations for suppliers that are Moparts sponsors?
I think there are conversion packages available.
Re: 413 with Dual Fours?? [Re: DRAG] #1349664
12/13/12 05:57 PM
12/13/12 05:57 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Re: 413 with Dual Fours?? [Re: 62maxwgn] #1349665
12/13/12 08:41 PM
12/13/12 08:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, my 64 413 single quad (might be the difference here) had the small bolt pattern and the small air horn diameter. Some one mentioned drilling the Ebrock for the old pattern and that jogged a memory cell. Did that too, back in 88, but had to spring for a new filter housing.
Re: 413 with Dual Fours?? [Re: Supercuda] #1349666
12/13/12 09:27 PM
12/13/12 09:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the small air inlets were standard on all chrysler afb's, with exception of '64 s/s, until '68 model year.
