best intake for a magnum 360 #1349614
12/11/12 05:12 PM
12/11/12 05:12 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Hey guys, Im going to run a carb intake on my 5.9 magnum engine and was wondering what popular opinion is on which one is best. I'm gonna scrap the serpintine stuff and stay with the classic look and I'm thinking an edlebrock air gap but have heard only the crosswinds intake has the proper location holes for the brackets and accessories for running the old school stuff. I appreciate any info and opinions on the subject and thank you all. Clay
Re: best intake for a magnum 360 [Re: Clayton] #1349615
12/11/12 06:13 PM
12/11/12 06:13 PM
scratchnfotraction Offline
the magnum airgap rpm intake can be had for the magnum intake bolt pattern as well as the old LA style heads. they cost about the same.
crosswind has some issues from what I have read and are a poor intake as for fit.
I have run the airgapRPM on a SB and just went RPM on my 440 truck.great throttle responce and torque.
Re: best intake for a magnum 360 [Re: scratchnfotraction] #1349616
12/11/12 10:49 PM
12/11/12 10:49 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You dont have much choice. RPM, M1, or Crosswind unless you drill the heads for LA intakes
Re: best intake for a magnum 360 [Re: AdamR] #1349617
12/11/12 11:11 PM
12/11/12 11:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would do the air gap rpm intake. I think it will work so long as you don't run a/c.
Re: best intake for a magnum 360 [Re: DaytonaTurbo] #1349618
12/11/12 11:33 PM
12/11/12 11:33 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have both The Crosswinds & the Edelbrock Air-Gap
The Crosswinds I've used 6 of the so far & still own 2 one of them with 45K trouble free miles
They work perfect when using a RV2 & v belt accessory drive with NO mods the anything
The Edelbrock fits with serpentine drive the best but requires spacers to be made to make the brackets bolt on & be used
The Crosswinds is $100+ cheaper new
Bouchillion kickdown kit & throttle cable bracket work great for both no matter what carb you put on it
Re: best intake for a magnum 360 [Re: BulletBob] #1349619
12/11/12 11:39 PM
12/11/12 11:39 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's the Edelbrock
