Re: cable or solid rod for gas pedal
[Re: 70dusterjohn]
#1349119
12/10/12 03:46 PM
12/10/12 03:46 PM
dartman366
Mt. Vernon, Ohio
Bob, I am running a Indy intake with a 2" spacer and a Jegs throttle cable bracket in mine and it has the origional slant six cable,,as said earlier they are a little longer.
[Re: dartman366]
#1349120
12/10/12 03:59 PM
12/10/12 03:59 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I run a /6 cable in my 65 B with MI and Dominator.Plenty of length.My kids 62 300 runs a stock solid rod with Holley intake and carb.He has never had any problems.We both run Poly mounts.Rocky
Chrysler Firepower
[Re: MR_P_BODY]
#1349124
12/10/12 06:11 PM
12/10/12 06:11 PM
Posts: 5,875 communist bloc of new jersey
jamesc
I prefer a cable BUT if you run fast enough its mandatory to have a foot loop and hard rod... I use the Locar
the fastest cars in the world use a cable
i was under the impression all were required to have a toe clip though if i read this correctly a cable system is not required to have a toe clip...either way any throttle i use will have one.
NHRA general regulations read as follows
1:12 THROTTLE Regardless of class, each car must have a foot throttle incorporating a positive-acting return spring attached directly to the carburetor/injector throttle arm. A positive stop or override prevention must be used to keep linkage from passing over center and sticking in an open position. In addition to return springs, some means of manually returning the throttle to a closed position by use of the foot must be installed on all altered linkage systems except hydraulically or cable-operated systems. Per Class Requirements throttle control must be manually operated by driver’s foot; electronics, pneumatics, hydraulics, or any other device may in no way affect the initial throttle operation. In Super Street, Super Gas, Super Comp, and certain E.T. bracket classes, timed throttle stops are permitted that use pneumatics and or electronics to modulate the throttle after initial launch. Cable throttle systems permitted. NHRA-accepted hand controls for the physically challenged permitted. Choke cables and brazed or welded fittings on steel cable prohibited. No part of throttle linkage may extend below framerails.
[Re: VernMotor]
#1349129
12/10/12 09:44 PM
12/10/12 09:44 PM
Posts: 3,459 Dandridge TN
Dabee
Dandridge TN
Have had a lot of problems with the Lokar cable..not a good grade of cable. good for a street rod.
Agree the cables fray. I replaced my lokar cable with a rod last year.
[Re: junkyardmaxie]
#1349130
12/10/12 09:56 PM
12/10/12 09:56 PM
Posts: 9,871 MI, usa
dvw
MI, usa
cable wont reach carb to short .M1 INTAKE WITH 2" SPACER .has any one change over to solid rod ? whats involved ? pictures . or just buy a new adjustable cable kit from summmit? input please THANKS [/quote
Stock six cylinder cable reaches to the front carb no problem. Doug
[Re: jamesc]
#1349132
12/10/12 10:09 PM
12/10/12 10:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pretty hard to PUSH a cable unless its BIG like on my steering on my boat(which is 1/2" small diameter)... but I could be wrong here
[Re: RodStRace]
#1349134
12/10/12 10:20 PM
12/10/12 10:20 PM
MR_P_BODY
Morse cable, like a shifter... http://www.jegs.com/p/JEGS-Performance-P...763984/10002/-1
Yes.. they are a contained housing over the inner... but I think MOST of us have a free length of inner cable exposed which if you try to push just flexes as in the pic above.... granted I use a cable with twin return springs per NHRA
[Re: jamesc]
#1349137
12/10/12 11:00 PM
12/10/12 11:00 PM
Posts: 7,506 Az
Crizila
Az
Cable. Makes life a lot easier.
Fastest 300
[Re: Crizila]
#1349138
12/10/12 11:31 PM
12/10/12 11:31 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I bought a lokar cable years ago. I went for the bling. It consisted of brackets and stops. But the worst was the housing. It was just a teflon braided line. Well guess what the cable cut into the teflon and the throttle hung. I use motorcycle or bicycle cable housing now. And buy the inner cable at lowes. Been working for years.
[Re: Leon441]
#1349139
12/10/12 11:49 PM
12/10/12 11:49 PM
MR_P_BODY
Being that I worked in the Fuel and exhaust lab I made my own cables for my set up... the first week or so when I built my car I used the old throttle cable (/6) and of course it broke launching off the line... so I made a new one and made a back up... and based on Murphy's law... since I have 2 it will never break.... and it hasnt since... lol
[Re: 3404]
#1349142
12/11/12 12:11 PM
12/11/12 12:11 PM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A morse cable will push as well as pull, stock type cables will not. The choice between a morse cable and a solid linkage will depend on the application and preference. A cable does allow more creativity. Anything beyond a stock OE/street type set-up, I personally would not use a stock style cable and I would have some kind of a toe hook on the pedal. I like the idea of being able to pull the throttle shut with my foot.
[Re: Crizila]
#1349145
12/11/12 09:23 PM
12/11/12 09:23 PM
Posts: 8,341 fredericksburg,va
cudaman1969
fredericksburg,va
I always had faster reaction times with a rod, I guess because of more friction with a cable with bends.
I used to have that problem - - - - when I was 20!! [/quote
Silly guy ha ha
[Re: 3404]
#1349146
12/11/12 09:27 PM
12/11/12 09:27 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
My DartSport had a solid rod, once setup it was easy to use and no maintenance.
My 69 Dart had a cable and boy did I have headaches with it. I bought a good stainless bicycle cable and redrilled the gas pedal so the cable was aimed perfectly straight into the cable tube. The main thing is that the cable can not have any extra tension on it after the carb has reached full throttle! If there is even a tiny amount of play left in the gas pedal after full throttle you will break the cable. I broke 3 before I got it all figured out.
[Re: ProSport]
#1349147
12/11/12 09:51 PM
12/11/12 09:51 PM
Posts: 1,288 Oregon
sg66mopar
These people will make you any kind of cable you need. Most of the racers in the Portland (Oregon) area, including myself, buy throttle cables from them. http://www.instrumentsales.com/(503) 239-0754 (800) 333-7976 The last one I bought was last year. It's about 18" long, bullet proof and only cost about 40 bucks, built to my specs.
[Re: sg66mopar]
#1349148
12/12/12 01:01 PM
12/12/12 01:01 PM
therocks
Niles , Ohio
Gus I have the same bracket.I got it from Mancinis for like 20 bucks at Carlisle.Works great with the M1 and Dominator.Rocky
Chrysler Firepower
[Re: therocks]
#1349149
12/12/12 01:11 PM
12/12/12 01:11 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
All cars that leave my shop to be raced have a solid rod and a toe clip for safety.
BB, TT5,Procharged 3300lb Street Car 4.79/154
