Mopar 4340 stroker crank key #1349108
12/10/12 02:35 PM
12/10/12 02:35 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Just received my Mopar 4340 4" stroker crank this morning,and a quick inspection revealed that there was a slot for a crankshaft key for the crank sprocket. Does anyone have a part number for this key that goes in this hole? Would one of these work?
http://www.summitracing.com/parts/dcc-5249822/overview/
Re: Mopar 4340 stroker crank key [Re: mshred] #1349109
12/10/12 02:55 PM
12/10/12 02:55 PM
If it is machined for a "Woodruff"( I think that is the coorect name for them ) measure the width and length of the keyway and go from there A Woodruff key is like a half moon, the other square keyways are half a square the same depth all the way from end to end
Re: Mopar 4340 stroker crank key [Re: Cab_Burge] #1349110
12/10/12 03:12 PM
12/10/12 03:12 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Re: Mopar 4340 stroker crank key [Re: Jeremiah] #1349111
12/10/12 05:19 PM
12/10/12 05:19 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Gosh I really had a brain fart when I posted this question...It is the crank woodruff key that I needed (I don't know why I called it the "key"...like a secret or something lol) and I just realized that I could pull it out of my old crank and pop it into the new one..DOH
Thanks for the info though guys!
