Small block oiling question
#1348567
12/09/12 07:03 PM
12/09/12 07:03 PM
Posts: 2,459 Sydney,Australia
tex013
Sydney,Australia
Hi, i presume on a small block LA the rockers oil like a big block?At 2 different points you will get oil feed to the rocker shaft.The last 318 i did oiled to the top on #1 and #6 TDC i have a customer supplied motor that will not oil to the shafts - i have rotated the motor over and checked at about every 15-20 degrees of crank. i have taken the rockers off,crane,and found the shaft were fitted incorrectly which does not give me a great amount of faith in the rest of the motor build up.This is a 408ci with Eddy heads. With hand priming,spinning,the oil pump i have oil to the lifter galley.There is oil drain back in the valley. Bearings misaligned ? Thoughts ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Small block oiling question
[Re: tex013]
#1348568
12/09/12 07:17 PM
12/09/12 07:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Use a piece of 1/16 tig rod(or something similar) and with the rocker shafts off poke through the rocker feed holes to make sure they are open... then the next thing would be the cam bearing might be spun or installed wrong(the holes not lined up) in the #2 and #4 cam journals.... keep the rocker shafts off till you figure out whats hapening
[Re: MR_P_BODY]
#1348569
12/09/12 07:52 PM
12/09/12 07:52 PM
tex013
Sydney,Australia
Thanks MrPeabody, this motor has never been fired since the being built.my bet would be the cam bearings though i will put a rod down both feed holes to confirm Tex
[Re: tex013]
#1348570
12/09/12 07:59 PM
12/09/12 07:59 PM
MR_P_BODY
The only way you will know is if you slowly turn the crank with the rod down the hole you should see it drop in when the cam hole lines up... its too close to measure based on distance(thickness of the cam bearing... but its strange that both sides dont oil.. thats 2 different bearings
[Re: tex013]
#1348571
12/09/12 08:13 PM
12/09/12 08:13 PM
MR_P_BODY
The only other thing I can think of is the head gaskets... put on wrong BUT if they are then the alignment pins arent in there
[Re: MR_P_BODY]
#1348572
12/09/12 08:27 PM
12/09/12 08:27 PM
tex013
Sydney,Australia
MrPeabody, if you didn't know about the the bearing feed i guess both bearing could be wrong. Head gasket i would have thought even without dowels the alignment would be close enough - maybe not. thanks again
Tex
[Re: tex013]
#1348573
12/09/12 09:10 PM
12/09/12 09:10 PM
tex013
Sydney,Australia
MrPeabody, are there supposed to be necked headbolts with the eddy head ?
Tex
[Re: tex013]
#1348574
12/09/12 09:14 PM
12/09/12 09:14 PM
Posts: 15,487 Florida
scratchnfotraction
what yr engine block? what cam? some of the magnum roller cams are not drilled to oil the LA rockers. some magnum blocks are not drilled to oil LA rockers. IIRC,magnum head gaskets would block the oil feed on a LA block.
[Re: scratchnfotraction]
#1348575
12/09/12 09:49 PM
12/09/12 09:49 PM
tex013
Sydney,Australia
ok,thanks for the reply engine casting date appears to be 24 4 90 casting number - 53008921360 if this is a magnum block you would need pushrod oiling plus don't the magnum motors use a pedestal type rocker similar to a chev ? looking down where the oil feed port in the head is you can see the head bolt,ptting a rod down there only goes about 1 1/2"
Tex
[Re: tex013]
#1348576
12/09/12 10:13 PM
12/09/12 10:13 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Two thoughts on this - either the cam bearings are not in properly (I've found a couple brands that the holes will block off as much as 1/2 the feed hole...) Ort he hardeware that holds the rocker shafts down could be closking the passage in the heads. Pull the rocker shafts and see if there's any oil coming up when you preoil and turn the engine over. If not, I'd pull the cam out...
[Re: moper]
#1348577
12/09/12 10:26 PM
12/09/12 10:26 PM
tex013
Sydney,Australia
there is no oil with the shafts off
Tex
[Re: tex013]
#1348578
12/09/12 10:27 PM
12/09/12 10:27 PM
moper
Columbia, CT
Then it's in the bearings or gasket...
[Re: moper]
#1348579
12/09/12 10:31 PM
12/09/12 10:31 PM
tex013
Sydney,Australia
or magnum block not drilled thanks Tex
[Re: MR_P_BODY]
#1348581
12/09/12 11:18 PM
12/09/12 11:18 PM
tex013
Sydney,Australia
Mr Peabody, thanks will discuss with owner Tex
[Re: tex013]
#1348582
12/09/12 11:27 PM
12/09/12 11:27 PM
scratchnfotraction
Tex
90 would be a pre-mag roller cam block. it would be drilled for rocker shaft oiling.
the stock cam would also be drilled for rocker shaft oiling.
if aftermarket roller cam...may or may not be drilled
90 would also be oiling thru the block/heads LA style and thru hollow PRs with oil thru roller lifters. (gearing up for the magnum change over)
does it have a roller cam with roller lifters?
sounds like it is pointing toward the head gaskets, they could be for a magnum and blocking the passage to the head.
[Re: Cab_Burge]
#1348584
12/10/12 01:02 AM
12/10/12 01:02 AM
tex013
Sydney,Australia
Cab, that will be this arvo or tomorrow morning Tex
[Re: tex013]
#1348585
12/10/12 08:38 AM
12/10/12 08:38 AM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
I bought new edelbrock aluminium heads few years ago and didnt get any oil to the rockers at first. Oil passage in the head was not drilled through so the blockage was in the head.
-1965 Valiant 9.03s 358cu.in R5P7-
[Re: Ck[FIN]]
#1348586
12/11/12 06:32 PM
12/11/12 06:32 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Correct me if I'm wrong, but doesn't the oil go from the block, up past the head bolt, then along the bolt to a passage that goes up to the pedestal? I would think it'd be pretty difficult to get a piece of wire down past the head bolt and into the lower hole that lines up with the hole in the deck surface. Only way to know is to pull a head and check things out that way. I think the magnum head gaskets are drilled, but in case they aren't and you aren't sure if you have magnum gaskets or not, the magnum head gaskets have areas that the pushrods go through. Separate holes for each pushrod that is. If they misaligned the holes in the cam bearings then the cam won't be receiving oil either. If I remember correctly there's three holes per bearing on #2 and 4, so as long as the hole up from the main lines up, you'll have oil to the deck as well. I think I would disassemble the whole engine. Doesn't sound like the most trustworthy builder.
