Re: A dumb timing chain ? (sorry)
[Re: The Shocker]
#1348331
12/09/12 11:36 AM
12/09/12 11:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You'll be fine... but if you looked at the hole locations the pass side hole is lower so thats where you would put the bolt with the hole... no big deal
[Re: sam64]
#1348333
12/09/12 12:36 PM
12/09/12 12:36 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Beielve it or not , i already went to the parts house got the gaskets and switched the bolt in 1 hr.It does go in the top passenger side correct ?Also while were on the subject ,the gasket kit came witha big felt type washer.Does this go on the crank between the oil slinger and balancer ?This piece was not in there when i disassembled it.Do i need it before i put the cover back on ?
[Re: The Shocker]
#1348334
12/09/12 01:42 PM
12/09/12 01:42 PM
Posts: 15,487 Florida
scratchnfotraction
yes,bolt goes in top left corner.
the big felt washer goes on the damper first,then install the damper on crank. the felt washer is against the seal like a dust boot. on the outside of t-cover.
oil slinger inside t-cover for back side of seal.
do you have a metal oil dripper on the lower left bolt with the tang over in the right lower hole?
the oil thru bolt is early set up then they went to the metal oil driper.
no problems running both.
