Head Studs for Indy EZ heads #1348220
12/08/12 11:53 PM
12/08/12 11:53 PM
Las Vegas
afxcoronet Offline OP
Las Vegas
Need to get a set of head studs for my Indy EZs, any recommendations?
thanks,
Curtis
Taking over the World one win light at a time.
Re: Head Studs for Indy EZ heads [Re: afxcoronet] #1348221
12/09/12 12:11 AM
12/09/12 12:11 AM
Call ARP Monday morning to see if they offer a kit, if so get the part number and shop around If not contact Indy and have pateince and be ready to bend over
Re: Head Studs for Indy EZ heads [Re: Cab_Burge] #1348222
12/09/12 12:28 AM
12/09/12 12:28 AM
Northern California
gtxjeff Offline
gtxjeff  Offline
Northern California
Be prepared to have the lower ones machined off or your headers won't fit.
Re: Head Studs for Indy EZ heads [Re: afxcoronet] #1348223
12/09/12 01:06 AM
12/09/12 01:06 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Can you measure the head to check length?I use tuds and the fit my edelbrock victors and I know the length of mine.I got my studs from summitracing
Re: Head Studs for Indy EZ heads [Re: afxcoronet] #1348224
12/09/12 01:49 AM
12/09/12 01:49 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Call Nick at www.compu-flow.com and he will hook you up
Gus
64 Plymouth Savoy
Dana 60
Re: Head Studs for Indy EZ heads [Re: gtxjeff] #1348225
12/09/12 02:07 AM
12/09/12 02:07 AM
AndyF Offline
AndyF  Offline
You don't need to cut off the studs, just buy shorter studs. ARP has the correct length studs in the catalog.
Re: Head Studs for Indy EZ heads [Re: AndyF] #1348226
12/10/12 01:20 AM
12/10/12 01:20 AM
Las Vegas
Las Vegas
Thanks guys, will make some calls tomorrow.
