Rebuild or replace my 383? #1348046
12/08/12 07:21 PM
12/08/12 07:21 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Hey people I have a question. My factory 383 is getting pretty tired after 40 years of hard work and I am starting to think ahead of either having a professional builder or a shop redo the engine or maybe buy a crate motor and upgrade to a 440?
I have heard so many horror stories about shops that do awful rebuilding work or make mistakes and cause failures almost immediately. I can't even think of anyone I could even go to who does this type of thing anymore around me.
Keeping the original numbers matching engine is great for purists, but is it easier and more cost effective to just by a readymade motor? Also i think the time would be much quicker with just a pull out and install the new engine that having to store the car at a shop while the original engine gets sent out for rebuild.
In the end am looking for something that is set up for long life, durability, fuel economy over lots of horsepower.
So how about some opinions on what to do? If you anyone knows of a good place to buy a ready done crate engine I would love to hear it.
Stu
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348047
12/08/12 07:53 PM
12/08/12 07:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i like 383's. used to really beat on them back in the day. i think they're worth rebuilding, just don't expect 440 performance. i think if i had a 383 to play with i'd do the 431 (440 crank in 383 block). i'd never let a machine shop put my engine together. most can't do the machining right and their bad advice and egos just complicate matters.
Re: Rebuild or replace my 383? [Re: lewtot184] #1348048
12/08/12 07:57 PM
12/08/12 07:57 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what would I do if I had a numbers matching RR?
I'd build a motor to beat on, and put the numbers block on a stand. If you didn't want the expense of building 2 motors right now, then I'd at least take it all apart, strip the block, sand blast stuff like timing chain, oil pan, valve covers, then put it all together in a "mock up" but with an empty inside -- no cam, no crank/rods/pistons, just make it all nice and pretty, then use it as a display in your bar/garage.
Stu, I know the distance is a bit far, but tell me what you want, I'll build it for ya! I'll even properly break it in on a well known, Mopar reputable machine shop here in Ohio--Kammer and Kammer's over in Dayton. that's where I took my stroker for dyno tuning.
**Photobucket sucks**
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348049
12/08/12 08:05 PM
12/08/12 08:05 PM
So Tom would that be me sending you my engine as how would the logisits of that work?
The other idea would be to drive the car out to you and have you do the work, and then drive it home. That would make a nice road trip for sure!
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348050
12/08/12 08:18 PM
12/08/12 08:18 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've even got a complete 383 here with flat top pistons (4bbl Hp version of the 383, not the 2bbl low compression version) that I could use as a core to start from. it's even still standard bore!
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348051
12/08/12 08:19 PM
12/08/12 08:19 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'm flexible! however you want to do it!
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348052
12/08/12 08:26 PM
12/08/12 08:26 PM
Ok i checked and it's about 5000 miles round trip and with the cost of fuel, lodging, and other stuff it's probably cheapest to just have you build it from your core and ship it back to me.
Why dont you work of a ball park figure and let me know in a PM what i am looking at price wize.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348053
12/08/12 08:51 PM
12/08/12 08:51 PM
Kirkland, Washington
Pacnorthcuda Offline
If you're going to put a non-numbers motor in your RR why would you NOT change to a 440?
Re: Rebuild or replace my 383? [Re: 70Cuda383] #1348054
12/08/12 10:13 PM
12/08/12 10:13 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
You know, I seriously thought about doing this vary thing with my numbers Road Runner, but then I thought na, the safest place for a numbers matching engine block is bolted to the car to which it was born. Because life is uncertain, e.g., fires, floods, robbery, vandalism etc., not to mention the human factor such as serious illness, sudden death, or just plan loosing interest. You'd get tired with a engine block rolling around your shop collecting dust, rust and taking up space. If you omit the numbers block now, there's a much higher likelihood it will never go back in the car.
This engine has survived for 40+ years, if rebuilt right it'll last another 40+. Do a basic but effective rebuild, then find a bottom of the barrel Belvedere/Satellite or Coronet and bolt in your 572 Hemi crate engine. OR sell your numbers car and buy what you really want.
Just throwing out some ideas.
Re: Rebuild or replace my 383? [Re: CompSyn] #1348055
12/08/12 10:17 PM
12/08/12 10:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Pull the numbers engine out and it'll never make it back into the car. First decide if you care about numbers. If you do, then have your block rebuilt. I'm sure you have friends/contacts in the area who could steer you to an engine builder they've used. If you just want to do a different engine so you can do a straight swap, step up to a 440. There's no real reason not to.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348056
12/09/12 03:30 PM
12/09/12 03:30 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
"In the end am looking for something that is set up for long life, durability, fuel economy over lots of horsepower."
With this information I would rebuild your original 383. 383's are great engines and will get better fuel economy than a bigger engine.
The safest place for your original engine is between the framerails of your car unless you're really abusing it and with a 383 really abusing it means running it out of oil or buzzing it past 6500.
I would find someone you can trust locally or even send it to a known machinist on this board. If you build another engine then you have to store or sell your matching #'s engine after it's all over so you'll probably be tripping over it for years as opposed to being inconvenienced for a few weeks with the engine pulled out of your car.
Buy some good pistons (I would get Diamond to spec some that will work out to stock 69 compression height) have it balanced, hardened seats in the 906's with slight bowl porting and have an expert recommend a cam based on all the other specs of the car.
Sheldon
Re: Rebuild or replace my 383? [Re: RUNCHARGER] #1348057
12/09/12 04:16 PM
12/09/12 04:16 PM
I'm working with a Moparts member on this as we speak and hopefully will get a nice rebuilt engine by early 2014.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348058
12/09/12 05:00 PM
12/09/12 05:00 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Stu
Cool that you got a plan...
(I'd bag the original-drop something in...No worries)..
There seriously is no one out there in San Fran that you'd feel comfortable with having do a 383???
Re: Rebuild or replace my 383? [Re: RSNOMO] #1348059
12/09/12 05:34 PM
12/09/12 05:34 PM
...............Nope and how sad is that! I have heard horror stories from every shop i know..
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348060
12/09/12 05:43 PM
12/09/12 05:43 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Re: Rebuild or replace my 383? [Re: Topcat] #1348061
12/09/12 09:54 PM
12/09/12 09:54 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would drop in a 6.1L 3rd gen with the factory wiring harness.
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348062
12/09/12 10:03 PM
12/09/12 10:03 PM
But there are probably dozens of guys that could rebuild a VW bug motor with their eyes closed and a refer in their mouth!
Re: Rebuild or replace my 383? [Re: Pacnorthcuda] #1348063
12/10/12 08:41 AM
12/10/12 08:41 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Re: Rebuild or replace my 383? [Re: ireland383] #1348064
12/10/12 10:25 AM
12/10/12 10:25 AM
I thought that was pretty funny too!
Re: Rebuild or replace my 383? [Re: MidPenMopar] #1348065
12/10/12 02:43 PM
12/10/12 02:43 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Stu..I am with you on this one. When it comes to a reputable Machine Shop/Engine Builder, especially for us MOPAR types, the pickings are slim to none here in Northern CA. That being said, I would first try and see if Mopar Engines West can fit you in. They have an excellent rep here in this neck of the words. Albeit they do more with Hemis and such, but will not turn down a Mopar build as their schedule allows and they are Mopar specific. They are in the North Bay area so that keeps it close too. I am one who has had a nightmare of a time with my 383 build for my 66 Satellite project. What ever you do, do not contact California Street Machines in Suisun CA. They are the ones, "that screwed me with out the benefit on intercourse"......and numerous others I have talked to. Having just said that, I went with Bailey Brothers in American Canyon CA when I fixed my Crank issue this time last year. The are a Speed shop although they are more GM types than Mopar but their work is excellent and priced very reasonably and will work on any Marque. After that fix, my 383...which is quiet tame...still wouldn't perform correctly along with a rear main seal issue...so I pulled it again and upon inspecting the heads, found numerous "suspect" procedures that were built into them. I opted for the 440 Source Heads...great buy for the price I might add...and stock right out of the box they bolted up really nicely. Just some small clearance issues with the push rod sleeves that required some enlargement that my Brother and I were able to do ourselves. With the old heads...516's...the valve lash was next to impossible to get right and after inspecting the rocker geometry and lifter preload, found out that failures were built in to the 516's as well. With the 440 Source Heads, it went as smoothly as anyone could ask for. The guys down there in Lancaster CA @ 440 Source have a great attitude and tech service and advise...at least for me it was...plus a large data base on their stroker kits. I know I am getting a little long winded here Stu, but if your RR were mine, I would pull the 383 and use 440 Source 496 or 493 383 Stroker kits. You would have less block messaging and clearing issues than with the 440 crank... . John/Dart4forty, when he visited over the summer, suggested those 2 stroker kits for me if I ever want to go that route. From my conversations with 440Source and what I have purchased from them so far have given me a peace of mind now with what I am running. I like 383's and they can be made to perform and in some cases out run the 440's. That however depends upon how deep your pockets are. Finally, I would look into Hughes Engines "Whiplash Cam" for your RR. Just a freakin' awesome Cam. Keep me in the loop too if you need any more help with you RR build. I have built a few 383's myself...CA Street Machines doesn't count...so I have a little experience on what it takes to get it right. Remember this...The more you can do the build yourself, then the end results are on you and not from someone else you have relied upon...Good Luck on the decision....cr8crshr/Bill
