Reproducing Plastic Lettering?? #134785
10/10/08 04:00 PM
10/10/08 04:00 PM
Indy
rtse70 Offline OP
rtse70  Offline OP
Indy
If an original plastic part came with wording or date codes that are not on licensed reproduction parts, is there a way to transfer the information to the reproduction piece to make it more original? Can a mold be made of the wording and plastic poured in it somehow, then transferred to the new piece?
Re: Reproducing Plastic Lettering?? [Re: rtse70] #134786
10/11/08 01:43 AM
10/11/08 01:43 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
No, the part number, Pentastar, etc. have to be engraved into the mold so they are integrally cast with the part.
Re: Reproducing Plastic Lettering?? [Re: rtse70] #134787
10/11/08 10:57 AM
10/11/08 10:57 AM
GMP440 Offline
GMP440  Offline
Yes. You can do a resin casting of your part and out comes the part with the number.
Also, you can do a casting of just the raised numbers or other info. That can be done by a process called foil casting.
There is also another process called photoetch that can be done as well.
This is all from techniques through model car building.
