Differences in E-body transmission mount cross members? #1347843
12/08/12 01:03 PM
12/08/12 01:03 PM
Russ H. Offline OP
Russ H.  Offline OP
Hi All,
Not being an E-body guy,I need help IDing an E-body crossmember that came with a 4 speed transmission I bought some years ago. As I understand, the early model E-body cars (70-71-72) had a different crossmember than that of the 73 and 74s. It would be much appeciated if anyone could explain the difference between the 2 or better yet, post a picture.
Thank you,
Russ
Re: Differences in E-body transmission mount cross members? [Re: Russ H.] #1347844
12/08/12 04:21 PM
12/08/12 04:21 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think they are all the same.
Re: Differences in E-body transmission mount cross members? [Re: burdar] #1347845
12/08/12 04:32 PM
12/08/12 04:32 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
73/4 has a closer bolt spacing where it bolts to the crossmember than 70/2. T-bar crossmember is different also.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Differences in E-body transmission mount cross members? [Re: moparmarks] #1347846
12/08/12 06:29 PM
12/08/12 06:29 PM
Russ H. Offline OP
Russ H.  Offline OP
Thanks for the information. The bolt spacing on the crossmember I have is 4 3/4 inches. Am I right in thinking this would be from the 70/71/72 cars?
Russ
