This is something of an offshoot of my post where I had the pictures of my modified oil pan, windage tray & crank scraper
here.
Even though the pan is Milodon's version of the Street Hemi pan advertised as 6 quarts + filter, someone on the other thread asked whether the oil level was above the main sump baffle level with 6 qts in the pan. I didn't know, but I had ran the MP version of that pan previously w/ only 5 qts + filter (6 total in the system) because the OEM dip stick said that amount matched the "full" mark. I can verify that oil pressure up to 7000 RPM was pretty steady on the dyno and never saw any pressure-related issues running it that way until I got caught off guard w/ an oil leak.
Regardless, I set up the new pan w/ the rail horizontal to my work surface and started adding fluid 1 pint at a time to get an idea where the level ended up w/ respect to the main sump baffle:
- at 9 pints (4.5 quarts), the fluid level was just even w/ the edge of the baffle
- at 10 pints (5 quarts), it was sitting .1-.2" above the baffle (depending upon exactly where I measured it)
- at 11 pints (5.5 quarts), it was .35-.50" above...
- at 12 pints (6 quarts), it was .50-.65" above...
At that point I placed a used oil pan gasket and a 440 Source windage tray on the pan to check whether the tray was above, at, or below the oil level with 6 quarts in the pan. What I verified was the fluid was just starting to creep up into the louvres on the bottom of the tray.
This leads me to ask the question I posted in the subject line: How much oil gets "trapped" in a running engine? It's obvious that a 440 w/ 6 qts of oil + 1 in the filter surely isn't holding a full 6 quarts in the sump when spinning 6000+ RPM... but how much would you expect there to be?
In reading my old "Grumpy" Jenkins SBC racing engine book, he commented that their dry-sump system had evolved to a level of efficiency where they'd see the the oil level in the sump only drop 1/2 quart with the engine running at a pretty high RPM, as I recall.
But that doesn't give me a good understanding of how much a simple wet-sump system would be expected to "lose" to all the other places inside the engine where the oil would be flowing & collecting... And having a better feel for that would help me in coming up w/ a more educated guess-timate of how much oil should really be run w/ my new oil system mods.
Thoughts / experiences? Thanks.
