Which tire size? 15x10 rim, 275/60/15 or 295/50/15 #134750
10/10/08 02:18 PM
10/10/08 02:18 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I'm looking at buying tires for the 15x10's that I have. Seems BF Goodrich is re-tooling their Radial T/A RWL line and won't have any 295/50's until next year. I might be able to find a set of 275/60/15's which are a bit narrower and a little taller... I have 235/60's for the front.
What's the best tire size for a 10" rim? What are you running?
The Blue Goose
My instagram: Bossride
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134751
10/10/08 02:24 PM
10/10/08 02:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have 275-60-15's on 10" wide rims on the back of my stepside. Looks fine to me. The 295's are too short and would raise my cruising rpm so I keep buying the 275's.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134752
10/10/08 05:54 PM
10/10/08 05:54 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
275 and 295 will fit fine on a 10 inch wheel. Your 235 should be 26 inches tall. The 295 should be close to 26.5 inches tall. So you won't throw off the speedo if it's geared to that size tire. The 275 will be about 28 inches tall adding close to two inches of height.
Just some food for thought.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134753
10/10/08 07:30 PM
10/10/08 07:30 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Are you gonna put these on a 73 Satellite??? That 295/50 is a lot of tire. Springs moved in any???
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: Pacnorthcuda] #134754
10/11/08 12:07 AM
10/11/08 12:07 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have 275/50 on a 10" rim on my Demon.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: Pacnorthcuda] #134755
10/11/08 01:54 AM
10/11/08 01:54 AM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I have moved the back spacing of the wheels in to 5" and am running NOS old school shackles and air shocks for that Day 2 look....I know the 295 is a lot of tire... I think I have the room without moving the springs... the 275's are taller... the 295's are wider.
The Blue Goose
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134756
10/11/08 02:53 AM
10/11/08 02:53 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You don't want either of those tires. Trust me, 275/60/15 (the size I have on now, and the size in my car's sig pic) definitely has the perfect height for these cars, but the width just isn't there. My next tires will be 325/50/15, now there's a ballsy tire! They have the same overall diameter as those 275's but at least have an aggressive amount of width to them. At this diameter tire size, I have as much room as I need to extend the tires outwards, just got to watch the backspacing and quite probably throw an offset kit at the leaf springs to get the 325's to clear. Here's a thread from a while ago, with some nice pics:
https://board.moparts.org/ubbthreads/show...rue#Post4592036
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: DaytonaTurbo] #134757
10/11/08 09:43 AM
10/11/08 09:43 AM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
The 325 is a very good looking tire...
I want the RWL to match the fronts, though. What size rear rims do you have on your car?
The Blue Goose
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134758
10/11/08 11:08 AM
10/11/08 11:08 AM
Summerfield,FLorida
mousefink Offline
mousefink  Offline
Summerfield,FLorida
My 72 Coronet wagon has 10" drag stars with bfg 295/50/15's on teh back,just slightly inside of teh fender lip,maybe 1/4".The short tire keeps my gear ratio low to help out the big wagon from a start.
67 Charger 383 6 pak 68 Charger 383 Magnum 73 Charger 383 72 Coronet R/T 4 speed wagon 98 Dodge Ram
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: mousefink] #134759
10/11/08 12:21 PM
10/11/08 12:21 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
me and a friend both have 73-74 satellites i got we both have 295 50 15 on 10 wide rims i have 3 3/4 back spacing on mine(i like a deep dish) but i have to use air shocks(with just lil air) to get them not to rub he dont like the jacked up look at all and wanted his tucked under the car so after some measuring he bought the same tire (295 50 15) and some 15x10 stars with 5 1/2 backspacing and thay tuck under the car very nice almost looks like it was mini tubbed it does not rub anywhere even when the rear twist(pulling in some where) has took it and jerked it sisde to side at speed to see if it would rub his car is all compleatly stock(60k mile big block car)you can put your hand between the 1/4 and the side wall on stock 1/4 lips leafs have not been moved either and no spacers maybe he will post a pic of it on here
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: toplescuda] #134760
10/11/08 12:26 PM
10/11/08 12:26 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
my car the one with the air shocks 295 50 on 15x10 torque thrust 2,s
1971 charger
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: toplescuda] #134761
10/11/08 12:29 PM
10/11/08 12:29 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
last one of mine
1971 charger
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: toplescuda] #134762
10/11/08 01:05 PM
10/11/08 01:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Looks like the 325-50-15 is only available as a drag radial. Too bad they don't make them in the regular T/A line.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: Neil] #134763
10/11/08 01:37 PM
10/11/08 01:37 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I had 305/50/15 on my cuda from the BFG Euro T/A line but don't think they are offered in RWL only black wall.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: rrunner] #134764
10/12/08 12:06 AM
10/12/08 12:06 AM
Manitoba, Canada
Manitoba, Canada
I only have 7" rims on the back of mine, which I will be scrapping in favor of 10" rims when I buy tires again. To be fair, the 275's look a lot more narrow on 7" wide rims than they do on a 9 or 10" rim.
To be fair, the 275's aren't bad, and really, if you want a pure street tire, the 295 is about as wide as is easily available. The 295's are about 1-1.5" shorter overall than a 275/60/15 or a 325/50/15, but the 295 should be about an inch wider than a 275 but an inch narrower than a 325.
I like the white letter tire look as well, and duplicolor sells a tire paint pen you can use to color in the letters on your tires if you buy ones that are not RWL.
If the back of your car is not jacked up super high like mine, you would be happy with the 295's. The back of mine is lifted so high that it would look odd for me to give up any tire diameter. I'll be going with the bfg drag radials, or maybe the m/t et streets if I'm feeling it, but if you want a pure street tire, you're probably best off with the 295/50/15 in the regular bfg line.
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: BossRide] #134765
10/12/08 12:48 AM
10/12/08 12:48 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
I run 295 50s on my Bee.....
Re: Which tire size? 15x10 rim, 275/60/15 or 295/50/15 [Re: pro451bee] #134766
10/12/08 12:51 AM
10/12/08 12:51 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Another...........
