Page 1 of 3 1 2 3
1971 CUDA RUBBER BUMPER (REAR) #1347484
12/07/12 05:50 PM
12/07/12 05:50 PM
Sweden
71redcuda Offline OP
Sweden
Hi, I thinking of switch out my rear chrome bumper and install a original rubber bumper for my 71 cuda.
Is there anything particular i should think about before i make a switch?
Special brackets for bumper,or anything else?
Im looking for a original rubber bumper because i imagine they should fit better than an repro from Gene Gregory..
Let my know your thoughts..
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 71redcuda] #1347485
12/07/12 08:18 PM
12/07/12 08:18 PM
western australia
1cuda Offline
1cuda  Offline
western australia
the rear rubber bumper bolts straight on with the same brackets-only the fronts had unique brackets. good luck in finding a great original and what i`ve heard of the repro ones are not 100% like the factory ones.
i do like the look of rubber bumpers and they are a bolt on item so it doesn`t mess with things if you want it looking like the tag.
it also looks good with the chrome...
all the best
frank.
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 1cuda] #1347486
12/07/12 08:43 PM
12/07/12 08:43 PM
Sweden
Sweden
Thank you very much for the info Frank.
Best regards
Nicklas
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 71redcuda] #1347487
12/08/12 04:15 PM
12/08/12 04:15 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
first thought is,i will buy your chrome bumper if its oem..
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: cuda-sweden] #1347488
12/11/12 11:05 AM
12/11/12 11:05 AM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
damn, nice cuda! Post some more pics please, what options does it have?
the repo rear rubber bumper from Gene Gregory is very nice, I think compared to an original it would be very hard to tell the difference once painted an installed.
Good luck finding an original if you are set on that. Even with a "mint" original, if it has seen any rain in it's life chances are the rear studs are starting to rust and separate from the core.
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: ErikR] #1347489
12/11/12 11:11 AM
12/11/12 11:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Can't tell you about the Cuda bumper but the Gene Gregory Challenger bumper is about 1.25" wider that an OE Elastomeric bumper... Taking a chop saw to both ends of aa brand new bumper is scary....
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: ErikR] #1347490
12/11/12 01:30 PM
12/11/12 01:30 PM
western australia
1cuda Offline
1cuda  Offline
western australia
there was a thread not too long ago where someone had fittment issues with a repro rear rubber bumper on a cuda-he couldn`t get the ends tucked in enough because the thing was too wide-he had some close up pics of it and it just seemed to jut out at the wrong places. bottom line like most repro parts-we simply cannot make things like the factory did.
all the best
frank
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 1_WILD_RT] #1347491
12/11/12 02:04 PM
12/11/12 02:04 PM
Sweden
Sweden
This is exactly what om talking about!
Will not try to cut a new bumper and then try to fix it up..Im sure i will make a mess with it
ErikR
http://www.garaget.org/mypage/gallery.php?user=106330&album=43470
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 71redcuda] #1347492
12/12/12 04:02 PM
12/12/12 04:02 PM
middle of the country
aar1 Offline
aar1  Offline
Don't forget........ you will need a different Jack Hook to keep everything correct.
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: aar1] #1347493
12/12/12 05:55 PM
12/12/12 05:55 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
Got a question pertaining to that. If you had only one rubber bumper, along with a chrome bumper, what hook did you get? #100 for chrome, #101 for rubber, or both?
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 318 Stroker] #1347494
12/12/12 10:17 PM
12/12/12 10:17 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I like both chrome and rubber bumber looks, but I prefered the chrome bumpers on my 71 so it would break up all the color front and rear especially with a color keyed grille.
MLR426
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 318 Stroker] #1347495
12/12/12 10:24 PM
12/12/12 10:24 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I'd think you'd get the rubber bumper hook, you probably wouldn't want to use the metal bumper hook on the rubber bumper but vice versa would probably be fine - my I like the rubber bumper look front and back
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: shakerjoe] #1347496
12/13/12 12:56 AM
12/13/12 12:56 AM
GA
roadrunninMark Offline
GA
just following along
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: roadrunninMark] #1347497
12/13/12 01:18 AM
12/13/12 01:18 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I like the rubber bumper look also...just can't afford one yet....
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: MLR426] #1347498
12/13/12 11:26 AM
12/13/12 11:26 AM
St. Louis, Mo
3
St. Louis, Mo
MLR426
Nice choice on that great looking Cuda, Martin...
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 318 Stroker] #1347499
12/29/12 01:15 AM
12/29/12 01:15 AM
REH Offline
REH  Offline
100 is a dart hook and replaced the ‘Cuda 101 (rubber or steel) when it was discontinued. This is listed in the 1970 parts book. Superseded parts are listed in the 70-71 parts book.
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: REH] #1347500
12/30/12 03:47 PM
12/30/12 03:47 PM
Sweden
Sweden
Is there any kind of differences between 70 cuda rear rubber bumper and the 71 rubber bumpers?
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 71redcuda] #1347501
12/30/12 05:54 PM
12/30/12 05:54 PM
Sec.414,seat 12,White Sox Park
swapman Offline
swapman  Offline
I have both 70 and 71. I can't see any difference in the two rears. Nor should there be. The front repros from that gregory guy start out as all 71's. Then he cuts them down for the bigger valance opening of the 70.
If you must deal with him, be prepared for all kinds of delays, phone messages not returned and total indifference to you. This guy is a real piece of work. If I told you how I really feel, I would never be allowed on this site again.
Do you live near Hyylinge Sweden?
And that is a great looking car. Post some pics of the Swedish bikini team with the car
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: 318 Stroker] #1347502
12/31/12 05:57 PM
12/31/12 05:57 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
MLR426
Thank You Allen, I think it just looks better to help break up the body color.
MLR426
Re: 1971 CUDA RUBBER BUMPER (REAR) [Re: MLR426] #1347503
03/04/13 03:30 PM
03/04/13 03:30 PM
Sweden
Sweden
Have now found an unpainted original NOS rubber bumper for my cuda. Will post a few reference pictures of it here incase anyone find it intresting.
Nicklas
Page 1 of 3 1 2 3
