Good Evening and Merry Christmas.
Does any one have pics of what the upper A/C condensor brackets for a '71 B Body (Charger)?
I'm reworking (removing) the add-on A/C and replacing it with factory pieces. I'm down to chasing the small parts.
The radiator yoke for the Charger has 4 holes approx 3/8'. Two per side of the radiator opening. All the brackets that I have seen are a single stud set in a rubber bushing that would require aprox a 1/2" hole to mount. If it is just a matter of enlarging one of the existing holes, I'm fine with that. I would just like to see what the 71 brackets look like,
As always thanks to all who respond.
Omni
