hemi crate balancer problem #134680
10/10/08 09:19 AM
10/10/08 09:19 AM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
hi when i went to bolt up the repo hemi pulley on the new crate motor the pattern would not line up i grabed a 440 one same thing does anyone know if the bolt pattern on the new crates balancers are different or is this one messed
allan
Re: hemi crate balancer problem [Re: westfort] #134681
10/10/08 12:53 PM
10/10/08 12:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The original balancer and pulley had one offset hole, most of the new balancers have equally spaced holes.
Re: hemi crate balancer problem [Re: westfort] #134682
10/10/08 09:07 PM
10/10/08 09:07 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
I bought a new set of pulleys that were suppose to be for the new crate motor but wouldn't line up. They were used, someone had started elongating new holes.
Anyhow we were able to end up using the 440 one. I know the Hemi pulleys weren't cheap.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: hemi crate balancer problem [Re: westfort] #134683
10/10/08 09:32 PM
10/10/08 09:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If the rest line up just elongate the one hole.
Re: hemi crate balancer problem [Re: NITROUSN] #134684
10/15/08 10:06 PM
10/15/08 10:06 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
well i bought another one from mopar performance an the holes arent drilled the same as the one i got 2 years ago but there definately made by the same company bad news it doesent line up either i wish mopar would pull up there socks this crate is the 2008 version and im not sure if the old damper was drilled different my 440 pulley would not bolt up what a mess thanks for your input
Re: hemi crate balancer problem [Re: westfort] #134685
10/15/08 10:24 PM
10/15/08 10:24 PM
Snoopy Offline
Snoopy  Offline
Is the new Hemi balancer on the crate motors set up for the old (68-71) thick balancer pulleys or it it set up for the BB pulleys?
Re: hemi crate balancer problem [Re: westfort] #134686
10/15/08 10:29 PM
10/15/08 10:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Did you rotate the pulley untill the holes line up??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: hemi crate balancer problem [Re: hemi-itis] #134687
10/15/08 10:31 PM
10/15/08 10:31 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
oh about 100 times, the closest is one hole out buy apoxx 1/2 a diameter of the hole I just hate to bubble gum a new part theres definatly some problems with the damper I will get a new one and see, at least the dealer here cares
lol
Re: hemi crate balancer problem [Re: westfort] #134688
10/15/08 11:14 PM
10/15/08 11:14 PM
Snoopy Offline
Snoopy  Offline
The reason I asked about the pulleys was because of the alternator pulley alignment. If you use the original style crank and water pump pulleys, you will also need to use the correct original Hemi alternator pulley, assuming the the new pulley is the same as the original, with the exception of the mounting holes. If the new balancer is made for the BB crank pulley depth, you will be able to use the standard alternator pulley and the BB water pump pulley.
Re: hemi crate balancer problem [Re: Snoopy] #134689
10/16/08 08:46 AM
10/16/08 08:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , its setup to use B/RB pulleys and altenator placement, whats odd is they sell a spacer and a repop of a 69 up hemi lower pulley to fit the asymetric bolt pattern and not the symetric bolt pattern of the balancer they install on the engines ...
To the OP , you either have to buy a $400 plus used original or repop thick balancer , modify that one hole or only use 3 bolts.
An alternative is to go to a 66-68 pulley arangement by using std B/RB pulleys , but again if you have an early crank pulley the bolt pattern is going to be off on that one hole .
Re: hemi crate balancer problem [Re: JohnRR] #134690
10/16/08 06:32 PM
10/16/08 06:32 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
My crate motor has the thin balancer. I order alum pulleys from mancini. The crank pulley needed a .37" spacer to achieve alignment. I painted the pulleys black, and I think I had to elongate one hole. I think the pulleys were around $150.
THis was about 4 years ago, but everything is still fine.
hope this helps.
Re: hemi crate balancer problem [Re: westfort] #134691
10/17/08 07:45 AM
10/17/08 07:45 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
It's simple. The crate motor uses a balancer with the depth dimension like a 440. As for the bolt pattern, older balancers had one bolt hole positioned different than the newer balancers. Some of the stock pulleys had one hole elongated from the factory so they would fit on either balancer. Other pulleys didn't have the elongation, and only fit one balancer. So as has been done for years, rotate the pulley till it lines up with all the holes, and if it doesn't line up with one, elongate it a little, and it will be just like the factory pulleys that came that way.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
