Re: How to fix knurling on crank oil seal area?
[Re: domingo]
#1346757
12/06/12 11:36 AM
12/06/12 11:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Actually you dont need that knurl.. that was for the old rope seal... most new cranks are smooth for the rubber seal
[Re: domingo]
#1346763
12/06/12 11:56 AM
12/06/12 11:56 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
As Raff mentions, you do not need the knurling with a modern rubber type seal.
If you look at your Eagle, you will most likely see a failry heavy knurl on that crank, but it as well isnt really needed. I make adjustments to the Eagle cranks, but they will work without it.The cause of the leak was most likely NOT the knurl, but something else, and was fixed when you did the repair.
RIP Monte Smith
[Re: CompWedgeEngines]
#1346764
12/06/12 09:48 PM
12/06/12 09:48 PM
Posts: 331 Cincinnati Oh
fasthawk6
Cincinnati Oh
Thats bs i have 2 mp 4" cranks and both motors leaked out the rear main seal. I bought the antileak rear main bearing for one but since they quit making them i had to make my own anti leak rear main bearing for this one.
[Re: fasthawk6]
#1346765
12/06/12 11:49 PM
12/06/12 11:49 PM
MR_P_BODY
Are you saying the knurl stops leaks... right now I have 4 engines running and none of them have the knurl... none are leaking... 2 are 4" and 2 are 3.79"
[Re: MR_P_BODY]
#1346766
12/07/12 10:07 AM
12/07/12 10:07 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Domingo Whatever you please DO NOT knurl that surface area again. The factory knurl is fine but going over it I'm afraid you will create one heck of a problem. Even for a rope seal to survive on. There are many, many factors that come into play with rear crankshaft seals and I can only go by what the info you provided as I don't have the parts in my possession. So here's a few suggestions for you to consider. Suggestion #1 Measure how deep the groove is in the crankshaft. Mock the seal up in the block WITHOUT the crank and measure the I.D. of the seal lip. Be careful not to flex the lip when measuring. Subtract the seal I.D. from the crank groove dimension. If it's less than .015" put a rope seal in there. If it's more than .015" you can take the chance with the rubber seal. However, I would suggest the minimum amount of crankshaft end play so the seal doesn't ride up on or out of the groove. This will effect the dynamics of the seal and quite possibly cause sealing problems. Suggestion #2 Have the surface welded and bring the diameter and surface finish back to spec. no need for the knurl. Suggestion #3 Put a rope seal in there and be done with it. Another thought Main and rod bearing clearances play a role in sealing this area as well. The more clearance the higher risk of sealing issues as excessive oil can overload the seals ability to stay in contact with the crankshaft surface. I hope this helps, Merry Christmas everyone!
[Re: roadhazard]
#1346767
12/07/12 12:03 PM
12/07/12 12:03 PM
CompWedgeEngines
Syracuse,NY
Thats bs Greg and you know it!... Its funny, I've been building engines for over 27 years and have never had to use a " anti leak" rear main...must have got lucky ???...
RIP Monte Smith
[Re: fasthawk6]
#1346770
12/09/12 11:29 AM
12/09/12 11:29 AM
MR_P_BODY
Of the cranks I have, none have the knurl... I dont recall the company name of the seal but it has a double lip and I assume the outer lip is a dust seal and the inner lip is the real oil seal
[Re: MR_P_BODY]
#1346771
12/09/12 11:40 AM
12/09/12 11:40 AM
fasthawk6
Cincinnati Oh
I am pretty sure the felpro is a double lip seal.The cranks that had the knurls where all factory 340 cranks. I will have the knurls added to the crank when the motor comes back out.I have had the pan off in the car 5 times before it hit the road.
