67 barracuda notchback rear window smaller than 68-69?
#1346538
12/05/12 06:00 PM
12/05/12 06:00 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
I was trying to install my 67 Barracuda notchback rear window, and the glass is too small it will fall thru the window opening. I know 67s came with rubber weatherstrippiung and no stainless moldings. I was wondering the 67 glass due to it coming installed with a weather strip or rubber molding is smaller than the 68-69 windows? I have been told nobody makes the 67 window mounting weatherstrip or rubber. I wanted to install it with no weatherstrip, just a rubber strip, silicone and put the rear moldings I got off a later model car.
Re: 67 barracuda notchback rear window smaller than 68-69?
[Re: domingo]
#1346543
12/05/12 06:54 PM
12/05/12 06:54 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
weird, then why my glass is falling thru as it was smaller....weird....I have another rear glass to comapre ill take it out and see what the deal is.
thanks!
The rubber seal takes up the space. The glass fits inside the opening, not over it.
[Re: Daty Rogers]
#1346549
12/05/12 09:06 PM
12/05/12 09:06 PM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
Lockstrip, windshield gasket retaining. Extruded material designed for pickups and van bodies. Chromed plastic type. 16 ft. strip. steelerubber.com 70-2196-52...Chrome..$ 40.10/ea. no NB gasket but I did find the locking strip, I used Ramcharger locking strip on mine http://www.rockauto.com/catalog/x,carcode,1228621,parttype,795 , no idea what is in kit but they do list NB -Daty
[Re: Daty Rogers]
#1346552
12/06/12 12:19 AM
12/06/12 12:19 AM
domingo
EL Master
EL Master
Lima, Peru
Welcome, you see distortion in the rear view mirror. Had a 67 NB back in the day, my friend HemiJim owns it now.
-Daty
that thing has some serious meat going on back there...
[Re: domingo]
#1346553
12/06/12 02:00 PM
12/06/12 02:00 PM
I'm not sure why you are having a problem. The back glass in my 67 is original to the car. The rubber and trim is from a junk 68-9 coupe with its back window broken out. Did the swap 20 yrs ago, but everything fit.
[Re: rick@laysons]
#1346555
12/21/12 11:50 PM
12/21/12 11:50 PM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
67 glass is smaller and shaped different than 68 and 69
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: domingo]
#1346557
12/22/12 04:14 AM
12/22/12 04:14 AM
Posts: 4,442 Texas
Daty Rogers
Texas
-Daty
440 B1 now, it has some serious heat. It screams.
-Daty
