Re: bodyguys opinion on how i should fix this
[Re: cudabitten]
#1346442
12/05/12 09:05 PM
12/05/12 09:05 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Either way, looks like you are going to be welding and grinding. I guess if I were doing it, I would try to get a dolly inside the cowl, and try to hammer everything flat and straight. Then weld up the puller holes. If thats not doable then section it out and weld your donor piece in. I would try those two approaches first, and if I didnt like how it was going, I would use the last resort and replace the whole piece. This is just how I would do it. I think you can definitely section it and make it look good. On the other hand would it be benificial to open the cowl up to get to any other areas that need attention?
I would try to work it and weld up the holes. If you start welding in sections, you run the risk of the welded seams coming back to haunt you at a later date. And if too much heat is applied you could end up with worse warpage than you have now. That can definitely be massaged back into shape.
[Re: chrisf]
#1346444
12/05/12 09:47 PM
12/05/12 09:47 PM
OLD318
My If that is the only damage to that cowl... Then I personally would NOT opt to replace it... You can weld those holes shut (slowly, carefully) and repair the area, much quicker than you can replace the whole cowl. I would not section the area out either... Just take your time... Fill 1 hole at a time and grind it smooth... Easy on the heat... Easy on the grinder... Say to yourself over and over.... "There are worse jobs on a mopar..." "There are worse jobs on a mopar... and you'll be fine! Best of luck to you
[Re: OLD318]
#1346445
12/06/12 12:20 AM
12/06/12 12:20 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
You might want to look into a shrinking disc as well. When they used the slide hammer, they stretched the surrounding metal. You'll need to shrink the metal in order to work it flat again. Welding the plugs will help, but may not be enough.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: chrisf]
#1346446
12/06/12 01:14 AM
12/06/12 01:14 AM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Relpacing the cowl isn't a real difficult job, we do them all the time.. just grind your plug weld smooth- carefully- then use the spot welder to replicate the spots.... I say this becuase most "home" spot welders out there don't have enough power to make a good structural bond on thier own. If you're good with a mig or tig you can make a puddle that looks like a spot... or you can do the old fashioned trick of using a pencil eraser in the wet primer to make a fake spot weld.. works great..
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: chrisf]
#1346449
12/06/12 03:47 PM
12/06/12 03:47 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
i had my soda blaster out today and thought i would roll my demon out of the shop and see how bad the damage to the top of the cowl is. in 1984 it was parked when he hit a road sign and pushed the hood edge into the cowl. he "fixed" it with the slide hammer. slide hammer holes and pretty wavy in about a 10" area
i have a complete 71 firewall so replacing the top of the cowl all isnt a issue but do i need to? want it correct and fixed right but just curious if i am creating more work than i need. vent fins arent damaged. replace the whole thing? patch? i think i am leaning towards the whole cowl.
opinions please
mig weld em shut, try to get it as good as you can and then after you are done, lead it. www.realsteel.com sells the stuff you need to lead it.
[Re: AdamR]
#1346451
12/06/12 11:52 PM
12/06/12 11:52 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
You can straighten it out, pull it with a stud welder, hammer dolly work, weld, grind etc. Probably easier to replace it.
stud welder, hammer & dolly, shrinking disc, weld holes & grind. done correctly you'll end up with very little filler & not having to replace the cowl piece which I imagine is a lot of work. Good luck.
