Stock oil pan. Where to find a decent pan? #1346301
12/05/12 03:08 AM
12/05/12 03:08 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Looking for a stock oil pan that will work with the stock pickup. I assume the cheap ($50) ebay pans are garbage but what about the Summit pans, are they any good? Other places to look?
http://www.summitracing.com/parts/sum-g3543/overview/year/1971/make/plymouth/model/satellite
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346302
12/05/12 08:37 AM
12/05/12 08:37 AM
SE PA
Yellow Fever Offline
SE PA
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346303
12/05/12 08:40 AM
12/05/12 08:40 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346304
12/05/12 01:44 PM
12/05/12 01:44 PM
East Coast
Blue Dodge Bob Offline
East Coast
What about "440Source"?
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346305
12/05/12 02:09 PM
12/05/12 02:09 PM
South Lyon, Michigan
6bblRoadrunner Offline
Try Dante's. Looks like they're now selling re-pop pans.
Re: Stock oil pan. Where to find a decent pan? [Re: 6bblRoadrunner] #1346306
12/05/12 02:13 PM
12/05/12 02:13 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I found a nice stock 402 pan with the pickup on ebay for $75.
You can find deals if you're not in a hurry.
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346307
12/05/12 02:34 PM
12/05/12 02:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Why would you put a 4 qt pan on your car? I do know that people think the 6qt "Hemi" pans are worth their weight in gold. So DB at Carlise wanted $225 for one, I laughed and walked away. E-bay has some decent pans, most are 7qt and come with the correct pick-up. Are you looking for a 5 or 6qt?
Coming soon!!!!
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346308
12/05/12 03:52 PM
12/05/12 03:52 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
I just received my Summit pan this morning. It is for a 360 and is gold anodized. It looks ok so far. I do not think it is as heavy as the factory one, but the factory pan still had oil caked on it.
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346309
12/05/12 04:12 PM
12/05/12 04:12 PM
Inver Grove Heights MN
74RR Offline
74RR  Offline
I'm very curious to see how the Summit anodized fits compared to the Ebay chrome special. Keep us updated on the fit.
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346310
12/05/12 04:30 PM
12/05/12 04:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think I got this 340 pan from Summit a few years ago, it was cheap if I remember right. It seems the same thickness as stock.
All my stockers were cutup to make deep pans out of. I wound up beating the dents out of the bottem of mt 7qt pan and reused it. I'd gladly take your old "oil caked " pan off your hands, did you buy a new one just because of that?
Re: Stock oil pan. Where to find a decent pan? [Re: Challenger 1] #1346311
12/05/12 05:09 PM
12/05/12 05:09 PM
dogdays Offline
dogdays  Offline
If it is not an aluminum pan it isn't anodized.
It is probably zinc-chromate dipped or whatever they use nowadays, if it is steel.
Re: Stock oil pan. Where to find a decent pan? [Re: Challenger 1] #1346312
12/05/12 06:53 PM
12/05/12 06:53 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
For what its worth, here are some pics of the Summit pan. The reason I am replacing it, is because I needed a center sump pan. It seems like a nice pan, we'll see how good it seals. It is steel, so I guess it is not anodized, just some gold metal conditioner.
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346313
12/06/12 10:41 AM
12/06/12 10:41 AM
74RR Offline
74RR  Offline
Is this the $50.00 Summit pan? I wonder if it will fit better than the Ebay $50.00 pan?
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346314
12/06/12 04:25 PM
12/06/12 04:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Which motor and body style?
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346315
12/06/12 11:44 PM
12/06/12 11:44 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I thought the Summit pan was baffled??
Re: Stock oil pan. Where to find a decent pan? [Re: Cab_Burge] #1346316
12/06/12 11:45 PM
12/06/12 11:45 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
383 in a '71 Satellite...
Re: Stock oil pan. Where to find a decent pan? [Re: Yellow Fever] #1346317
12/07/12 12:16 AM
12/07/12 12:16 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
64 Plymouth Savoy
Dana 60
Re: Stock oil pan. Where to find a decent pan? [Re: cudabitten] #1346318
12/07/12 01:46 AM
12/07/12 01:46 AM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
That's gold zinc, and it will rust if not painted.
Re: Stock oil pan. Where to find a decent pan? [Re: VITC_GTX] #1346319
12/07/12 03:36 AM
12/07/12 03:36 AM
I would buy and use the 1970-71 Hemi/440 6 pak pan with the 440 6pak 3/8 pickup I use them in every BB car I can, there better than great Several sources at different prices look around
Re: Stock oil pan. Where to find a decent pan? [Re: 74RR] #1346320
12/07/12 09:20 PM
12/07/12 09:20 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Yes it is the $50 pan. I'm not ready to install this yet, but I will dry fit it tomorrow and let you know how things go.
I do intend on painting it.
