SMOG TESTING MY DART...................... #1346201
12/04/12 11:50 PM
12/04/12 11:50 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just for giggles we`re going to smog test my Dart on the 5-gas analizer in school next Tue. and compare it to some modern stuff to see the differences. What do think this pig is going to spit out the pipes?
Re: SMOG TESTING MY DART...................... [Re: Thumperdart] #1346202
12/04/12 11:58 PM
12/04/12 11:58 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Wanna peg the machine????.....put a lit Bic Cig lighter next to the sniffer......usually pegs a 5 gas....what does that tell you?....lighting a cig puts 2 bad elements in you......like sucking on a tailpipe...LMAO
Re: SMOG TESTING MY DART...................... [Re: Chassisman] #1346203
12/05/12 12:02 AM
12/05/12 12:02 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Get it good and warm, then test it when it's 'happy' or up on the cam. It should be pretty good.
It will kick out a lot of HCs at idle due to overlap. It will almost certainly have a lot of CO at idle too, due to incomplete combustion and a rumpy cam likes rich at idle.
NOx might be high at high RPM, due to no EGR and probably high compression.
Re: SMOG TESTING MY DART...................... [Re: RodStRace] #1346204
12/05/12 01:18 AM
12/05/12 01:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Give it a vac leak after you get a base sniff and
do it again.... what is your A/F at mid range
Re: SMOG TESTING MY DART...................... [Re: MR_P_BODY] #1346205
12/05/12 01:26 AM
12/05/12 01:26 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
You could also add a gallon of denatured alcohol to your fuel tank...it helps with smog issues/ runs cleaner..
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: SMOG TESTING MY DART...................... [Re: RodStRace] #1346206
12/05/12 01:27 AM
12/05/12 01:27 AM
State of confusion
State of confusion
But do you think it will pass? Ya, 97 degs. of overlap should play hell under 2000r`s.............I`m mostly looking foreward to their faces when I put it in the bay and rattle the place apart. I`ll also compare a modern day 5-gas analizer to my "gross polluter"......could learn something plus I`ll note my wide band #`s at the tested rpm`s............fun stuff.....oh ya, I`ll be leaving this class w/an A and at least one cert. I`v learned more in two months(crash course)than I have in two years in terms of ALL of the sensors and their role in these modern marvels and how to test em to verify their condition(s).
Re: SMOG TESTING MY DART...................... [Re: MR_P_BODY] #1346207
12/05/12 01:30 AM
12/05/12 01:30 AM
State of confusion
State of confusion
I`ll do that...............it cruises between 13.5-14.3 last time I checked it.
Re: SMOG TESTING MY DART...................... [Re: mopardude318] #1346208
12/05/12 02:23 AM
12/05/12 02:23 AM
State of confusion
State of confusion
I thaught about a 91 pump gas test compared to the VP-100 I generally run but not sure about your deal..............something to think about.
Re: SMOG TESTING MY DART...................... [Re: Thumperdart] #1346209
12/05/12 03:36 AM
12/05/12 03:36 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
NoX should be good with all that overlap. Internal EGR.
Kevin
Re: SMOG TESTING MY DART...................... [Re: Twostick] #1346210
12/05/12 10:15 AM
12/05/12 10:15 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Between the overlap and running richer than stoich all the time, nox is going to be quite reasonable. HC's, not so much...
