Re: Triangulated four link question
[Re: Dabee]
#1345802
12/04/12 01:52 PM
12/04/12 01:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
handling and triangulated four link.
Interesting juxtaposition.
[Re: Supercuda]
#1345803
12/04/12 02:00 PM
12/04/12 02:00 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Sure works well for cars like mine.
Holden Torana's dominated racing in Australia, and uses a triangulated 4 link factory...
[Re: OzHemi]
#1345804
12/04/12 03:49 PM
12/04/12 03:49 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Millions of GM cars were built with a triangulated four link suspension.
[Re: feets]
#1345805
12/04/12 07:34 PM
12/04/12 07:34 PM
Supercuda
About to go away
About to go away
up yours
The go buy one. Just cause millions of wiggly butt GM's have it doesn't mean it's a good thing.
In order to get a triangulated fourlink to handle you have to use a lateral locating device, making in somerthing other than a four link.
So OZ, your Torana running a panhard or watts? Bet it is.
[Re: Supercuda]
#1345806
12/04/12 07:48 PM
12/04/12 07:48 PM
OzHemi
Garden Grove, CA
That is a bet you would not win then...
And plenty of them being raced without them too.
[Re: OzHemi]
#1345808
12/04/12 08:05 PM
12/04/12 08:05 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Trianglated means the uppers, or maybe lowers if those are the ones that are at an angle, keep the rearend centered, no need for a panhard bar or Watts linkage.
Straight bars would probably need a panhard bar or Watts link, depends on how good the installation is, and how hard/soft rubber/metal the bushings are.
Along with the shock mount and spring mount, etc.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Supercuda]
#1345810
12/04/12 08:29 PM
12/04/12 08:29 PM
amxautox
They wiggle because they have soft rubber bushings for comfort off the showroom floor/dealer lot. Not to mention the weak U shaped bars that really can't support much side load. THATS why the bars need to be replaced with solid/hollow bars, and use heim/saphirical ends for the best results/adjustability/handling.
Tom
author unknown
