Sealing timing cover/water pump bolts?
#134534
10/09/08 10:26 PM
10/09/08 10:26 PM
Posts: 1,202 California
polkat
mopar addict
mopar addict
California
Just wondering which of these bolts need sealing, and if simple silicon will work okay?
Whoops, almost forgot, it's a small block (318).
Re: Sealing timing cover/water pump bolts?
[Re: polkat]
#134535
10/09/08 10:39 PM
10/09/08 10:39 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
It would be the bolts above and below the water passages in the timing cover (maybe not all 4 of them, can't recall). You can shine a flashlight in the bolt holes, if there is "no bottom", not blind, then you need RTV. Yes, a coating of RTV on the bolt threads should be fine.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: polkat]
#134538
10/09/08 10:52 PM
10/09/08 10:52 PM
GO_Fish
Maryland
one of the fuel pump bolts needs RTV, it goes through into oil.
Scott B.
[Re: GO_Fish]
#134539
10/10/08 08:36 AM
10/10/08 08:36 AM
if theyre tight, thery dont leak but thread sealant is recommended. I used it for the first time on this recent build. i only used it cause people said to- not because I ever had trouble with them leaking. same with exhaust studs
#134540
10/10/08 09:23 AM
10/10/08 09:23 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Use aircraft sealer. The thick black goopy stuff. Seals better than RTV and easier to clean off when removed.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
