Sealing timing cover/water pump bolts? #134534
10/09/08 10:26 PM
10/09/08 10:26 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Just wondering which of these bolts need sealing, and if simple silicon will work okay?
Whoops, almost forgot, it's a small block (318).
Re: Sealing timing cover/water pump bolts? [Re: polkat] #134535
10/09/08 10:39 PM
10/09/08 10:39 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
It would be the bolts above and below the water passages in the timing cover (maybe not all 4 of them, can't recall). You can shine a flashlight in the bolt holes, if there is "no bottom", not blind, then you need RTV. Yes, a coating of RTV on the bolt threads should be fine.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Sealing timing cover/water pump bolts? [Re: polkat] #134536
10/09/08 10:40 PM
10/09/08 10:40 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I've used anti-seize compound on the water pump bolt threads with great results.
Just seal all but the top center bolt and you'll be leak free.
Don't forget you need to mount the power steering and alternator bracket under some of the water pump bolt heads before you tighten them.
Re: Sealing timing cover/water pump bolts? [Re: In_The_Pink] #134537
10/09/08 10:51 PM
10/09/08 10:51 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Yea, I thought it would be all but the top, as I have water coming out of some and oil out of others. Thanks!
Re: Sealing timing cover/water pump bolts? [Re: polkat] #134538
10/09/08 10:52 PM
10/09/08 10:52 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
one of the fuel pump bolts needs RTV, it goes through into oil.
Re: Sealing timing cover/water pump bolts? [Re: GO_Fish] #134539
10/10/08 08:36 AM
10/10/08 08:36 AM
if theyre tight, thery dont leak but thread sealant is recommended. I used it for the first time on this recent build. i only used it cause people said to- not because I ever had trouble with them leaking. same with exhaust studs
Re: Sealing timing cover/water pump bolts? #134540
10/10/08 09:23 AM
10/10/08 09:23 AM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Use aircraft sealer. The thick black goopy stuff. Seals better than RTV and easier to clean off when removed.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Sealing timing cover/water pump bolts? [Re: moparmarks] #134541
10/10/08 02:43 PM
10/10/08 02:43 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
How about this same question on an RB (440)? Are any of the "front-end" bolts wet with oil or water?
Thanks,
Darren
Re: Sealing timing cover/water pump bolts? [Re: Ludington1] #134542
10/10/08 09:23 PM
10/10/08 09:23 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Anyone for the 440?
Thanks,
Darren
Re: Sealing timing cover/water pump bolts? [Re: Ludington1] #134543
10/11/08 12:12 AM
10/11/08 12:12 AM
Yes the 4 bolts for the water pump housing are wet. Use some sealer.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Sealing timing cover/water pump bolts? [Re: moparmarks] #134544
10/11/08 12:28 AM
10/11/08 12:28 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Okay, it's back together and not leaking. That's for all the replys!
