Control Arms #1345349
12/03/12 11:05 AM
12/03/12 11:05 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Looking for tublar control arms for an a-body. Want them to work with factory front ends and have heim joints not bushings. Anyone know where I can find such a animal?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Control Arms [Re: 1967dartgt] #1345350
12/03/12 11:10 AM
12/03/12 11:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Control Arms [Re: 1967dartgt] #1345351
12/03/12 12:11 PM
12/03/12 12:11 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Bondo Bob,right here on Moparts.
Re: Control Arms [Re: 1967dartgt] #1345352
12/03/12 12:30 PM
12/03/12 12:30 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Bretts friend Tory
Re: Control Arms [Re: fishy340] #1345353
12/03/12 12:49 PM
12/03/12 12:49 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: Control Arms [Re: RobX4406] #1345354
04/14/13 12:54 PM
04/14/13 12:54 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I'm also looking for info. on this subject anyone no the weight diff. on these items compared to stock ......Thax.
Re: Control Arms [Re: racerx] #1345355
04/14/13 03:40 PM
04/14/13 03:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have the RMS ones, the weight is negligible but you can dial a lot more caster in and it helps loosen the front up some.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Control Arms [Re: racerx] #1345356
04/14/13 08:07 PM
04/14/13 08:07 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
not sure what the weight on control arms is.I can tell you the whole rms set up i have,got me over 110 lbs off the nose of my cuda.
Re: Control Arms [Re: Dodgem] #1345357
04/15/13 12:37 AM
04/15/13 12:37 AM
Toronto
mshred Offline
mshred  Offline
Toronto
RMS
http://www.reillymotorsports.com/store/home.php?cat=265
More than happy with my RMS uppers and I street drive the hell outta my car with them too!
Re: Control Arms [Re: mshred] #1345358
04/15/13 12:48 AM
04/15/13 12:48 AM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
About this topic.. Any one try these???
http://chucker54.stores.yahoo.net/bebofuadupco.html
/Tom
Re: Control Arms [Re: TomsCharger70] #1345359
04/15/13 02:40 AM
04/15/13 02:40 AM
Thats the ones I like, my freind has them on his 1968 Dart, mid nines at 141 MPH
Re: Control Arms [Re: Cab_Burge] #1345360
04/15/13 07:58 AM
04/15/13 07:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have the RMS arms. They are a nice piece, last time i did the front end I used RMS arms and strut rods. If I remember I believe it has about 5* of positive caster now. While it does take some steering effort it drives flawlessly with that much positive caster. Since I did the front end work and went to a drag radial it almost doesn't need a steering wheel on the track
68 Barracuda Formula S 340
Re: Control Arms [Re: Bad340fish] #1345361
04/15/13 09:32 AM
04/15/13 09:32 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I highly recommend Bondo Bob's control arms. they are a work of art. I felt bad about bolting them to my junk
Re: Control Arms [Re: sixpackgut] #1345362
04/15/13 09:58 AM
04/15/13 09:58 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I own sell and install the SPC uppers regularly. They are the only double adj arm on the market that makes alignment much easier. I am not sure why you would want heim joints on the arms unless you don't care about the noise or short life.
Re: Control Arms [Re: BergmanAutoCraft] #1345363
04/15/13 10:06 AM
04/15/13 10:06 AM
Hilltown Pa
Hilltown Pa
What do the spc ones weight? Look really heavy like heavier then factory.
Re: Control Arms [Re: 1967dartgt] #1345364
04/15/13 06:15 PM
04/15/13 06:15 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Been running Aroura heim joints now for 15 years on my upper control arms and they are still tight. Not noisey either.
Leon
Re: Control Arms [Re: TomsCharger70] #1345365
04/15/13 07:09 PM
04/15/13 07:09 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
/Tom
At 240.00 a side , that my friend , is pride.
Re: Control Arms [Re: fishy340] #1345366
04/16/13 10:17 PM
04/16/13 10:17 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Hmm....don't no how u were able to save that much weight i'm assuming u r includeing the streeing box to Bob's frontend kit clams of and i quote 24-30 lbs. It varies from A body cars to B & E body cars.I would not think that the b/e body car that much difference
Re: Control Arms [Re: racerx] #1345367
04/16/13 10:29 PM
04/16/13 10:29 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I agree. The total weight of a complete b body front end 123 lbs.
JAKES AUTOMOTIVE
