Control Arms
#1345349
12/03/12 11:05 AM
12/03/12 11:05 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looking for tublar control arms for an a-body. Want them to work with factory front ends and have heim joints not bushings. Anyone know where I can find such a animal?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Control Arms
[Re: racerx]
#1345355
04/14/13 03:40 PM
04/14/13 03:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have the RMS ones, the weight is negligible but you can dial a lot more caster in and it helps loosen the front up some. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: Control Arms
[Re: racerx]
#1345356
04/14/13 08:07 PM
04/14/13 08:07 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
I'm also looking for info. on this subject anyone no the weight diff. on these items compared to stock ......Thax.
not sure what the weight on control arms is.I can tell you the whole rms set up i have,got me over 110 lbs off the nose of my cuda.
Re: Control Arms
[Re: Bad340fish]
#1345361
04/15/13 09:32 AM
04/15/13 09:32 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I highly recommend Bondo Bob's control arms. they are a work of art. I felt bad about bolting them to my junk
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Control Arms
[Re: BergmanAutoCraft]
#1345363
04/15/13 10:06 AM
04/15/13 10:06 AM
1967dartgt
Hilltown Pa
What do the spc ones weight? Look really heavy like heavier then factory.
Re: Control Arms
[Re: 1967dartgt]
#1345364
04/15/13 06:15 PM
04/15/13 06:15 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Been running Aroura heim joints now for 15 years on my upper control arms and they are still tight. Not noisey either.
Leon
Re: Control Arms
[Re: fishy340]
#1345366
04/16/13 10:17 PM
04/16/13 10:17 PM
Posts: 4,074 Mo.
racerx
Mo.
Hmm....don't no how u were able to save that much weight i'm assuming u r includeing the streeing box to Bob's frontend kit clams of and i quote 24-30 lbs. It varies from A body cars to B & E body cars.I would not think that the b/e body car that much difference
