crate hemi balancer #134527
10/09/08 09:54 PM
10/09/08 09:54 PM
Canada
W
westfort Offline OP
westfort  Offline OP
W
Canada
hi when i went to bolt up the repo hemi pulley on the new crate motor the pattern would not line up i grabed a 440 one same thing does anyone know if the bolt pattern on the new crates balancers are different or is this one messed
allan
Re: crate hemi balancer [Re: westfort] #134528
10/10/08 09:29 AM
10/10/08 09:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The repo pulley might be for an original balancer which had an asymetric bolt pattern as would be your 440 pulley , the factory changed to a symmetric bolt pattern which is more that likely what the balancer on your crate motor , I have that balancer at home I'd have to check it out tonight.
Re: crate hemi balancer [Re: JohnRR] #134529
10/10/08 05:14 PM
10/10/08 05:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, crate motor dampers have the symmetrical bolt pattern. Either open up the one mismatched hole in the 440 pulley and use that, or open up the same hole in the repro hemi pulley and use that with a spacer. It's an early bolt pattern vs late bolt pattern issue + the fact the crate motor has a 440 damper as John said.
