When to replace converter? #1345205
12/02/12 11:10 PM
12/02/12 11:10 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
How often do you replace or do you have them sent back to be gone through? I'm going to purchase a trans from cope first of the year and was wondering if I should replace it. I've had it in car since 2007 with a good bit of passes and street driving... It's a 8" 5200 ptc. Thanks in advance.
Re: When to replace converter? [Re: 416scamp] #1345206
12/02/12 11:33 PM
12/02/12 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If there isnt anything wrong with it, why would you
Re: When to replace converter? [Re: 416scamp] #1345207
12/02/12 11:34 PM
12/02/12 11:34 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I got a 8 inch turbo action converter...bought it new in 1983....had to have a hub replaced on it back in the 90s...other wise it still being used today...unless the car has slowed down or something that indicates the converter is or has gone bad...use it.
Tony
70 AARCuda Vitamin C
Re: When to replace converter? [Re: 70AARcuda] #1345208
12/03/12 12:20 AM
12/03/12 12:20 AM
If it ain't broken, don't fix it
Re: When to replace converter? [Re: Cab_Burge] #1345209
12/03/12 01:12 AM
12/03/12 01:12 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
My Ultimate has been behind three different motors with no issues
5.53 @ 125 1/8th on the launch control..more left in her!
Re: When to replace converter? [Re: Eric] #1345210
12/03/12 02:20 AM
12/03/12 02:20 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
x 99 on why replace if the speed or ET has not suffered ALSO .. if you are not regularly toasting your ATF.
Re: When to replace converter? [Re: dOoC] #1345211
12/03/12 02:56 AM
12/03/12 02:56 AM
PA
moparacer Online content
moparacer  Online Content
PA
I ran a converter 3 years without problems.
Sent it back to be "freshened" at the beginning of the year and 2 races later the sprag starts slipping and drove me nuts for a month and a half till I figured it out.
If it were mine, I would run it until it exploded in a ball of flames then I would worry about it...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: When to replace converter? [Re: moparacer] #1345212
12/03/12 07:27 PM
12/03/12 07:27 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Thanks for the reply guys.. Wasn't sure just thought I would ask.
