holley 700 carb leaking #1345202
12/02/12 10:40 PM
12/02/12 10:40 PM
superstreet1896 Offline OP
having an issue with my 700 carb. While car is off, the primary bowl seems to be leaking. no leaks on outside. float level is fine when car is running, only prob is when the engine is off. has to be dumping fuel right down the intake, oil smells like fuel. if i hit accelerator pump it is bone dry. could there be an issue with the base plate? never seen this happen before. btw i do run a power valve
Re: holley 700 carb leaking [Re: superstreet1896] #1345203
12/02/12 10:51 PM
12/02/12 10:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
if it's dripping out of the booster, level is too high.
Re: holley 700 carb leaking [Re: rickraw] #1345204
12/02/12 10:56 PM
12/02/12 10:56 PM
nope its not leaking around there at all. thats what i thought at first
