brake caliper bracket question #1345119
12/02/12 07:54 PM
12/02/12 07:54 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
does anybody know if a 1976 plymouth fury would have the large caliper brackets like a cordoba etc,thanks
Re: brake caliper bracket question [Re: barryv] #1345120
12/02/12 08:09 PM
12/02/12 08:09 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Yes
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: brake caliper bracket question [Re: hemi71x] #1345121
12/02/12 10:19 PM
12/02/12 10:19 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
will i be able to use the 11.75 inch rotors. i saw the 76 fury at the junk yard. i dont know if its worth getting both assemblies with the rotors,calipers,spindles etc. it will run me approx 100 bucks for everything at the junkyard.thnx
Re: brake caliper bracket question [Re: barryv] #1345122
12/03/12 07:26 AM
12/03/12 07:26 AM
None
71rm23 Offline
71rm23  Offline
None
Hell, I'll buy them
Re: brake caliper bracket question [Re: 71rm23] #1345123
12/03/12 09:47 PM
12/03/12 09:47 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
i hope to take them off the car on the weekend at the junkyard. i wonder if they will make a noticeable difference from the disc brakes i have on my car now
Re: brake caliper bracket question [Re: barryv] #1345124
12/04/12 11:10 AM
12/04/12 11:10 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You'll be able to use 11.75 rotors as long as the brackets are from a car with that size rotors. But using the smaller rotors is no big deal.
Re: brake caliper bracket question [Re: Stanton] #1345125
12/04/12 11:03 PM
12/04/12 11:03 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
can i use the 76 fury spindles on my 70 roadrunner.thanks
Re: brake caliper bracket question [Re: barryv] #1345126
12/04/12 11:04 PM
12/04/12 11:04 PM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
you can buy my new large sliders for 125 and new beautiful drilled and slotted rotors for cheap ..screw that hasle
