8" convertor don't understand
#1345086
12/02/12 07:16 PM
12/02/12 07:16 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i had my convertor ste up for my motor 5500 stall, bout 550 hp worked great, was flashing bout 4500. put my new motor in bout 700 hp. ran on chassis dyno it flashed at 6200. i thought it would be the opposite. should of flashed lower? is this correct?
Hell Hath No Fury Like Mine
Re: 8" convertor don't understand
[Re: sixpacksteve]
#1345088
12/02/12 07:26 PM
12/02/12 07:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
More TORQUE moves the stall point UP...nothing to do with HP
[Re: MR_P_BODY]
#1345089
12/02/12 07:30 PM
12/02/12 07:30 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
thats fine. for some reason i thought it would move down. thanks
[Re: LSP]
#1345091
12/02/12 08:55 PM
12/02/12 08:55 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
peak is suppose to be some where around 6800-7000
[Re: sixpacksteve]
#1345092
12/02/12 09:10 PM
12/02/12 09:10 PM
Posts: 5,894 Florida
Locomotion
Would that be peak horsepower? I'll bet it's a big block. I've seen race combos that work well with converters that flash about 1,500 rpm less than the shift points. But it mainly depends on torque peak. Other variables affect the optimum #'s.
[Re: sixpacksteve]
#1345096
12/03/12 12:18 AM
12/03/12 12:18 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
Like most race parts you will have to find out what RPM the motor and trans go the fastest at, not a predetermined RPM My first pump gas stroker made peak torque at 4500 RPM and peak HP at 5600 RPM, the stupid car woould run its fastest ET and MPH by shifting it at or above 7200 RPM Go to the track and make a plan to run the car enough to make it consistent and then try shifting it at 5500 RPM in all gears for several runs and then try 6000 RPM for several and then 6500 RPM, the goal is to find the RPM that makes the car the fastest, with me anyways Once you find the RPM spread, say it runs the best by shifting at 6500 RPM but not lower than 6500 RPM or higher than 7000 RPM, try shifting it at 6700 RPM for several runs and whittle a away hundred RPM at a time until you find out what it likes at that track that day
[Re: Cab_Burge]
#1345097
12/03/12 09:22 AM
12/03/12 09:22 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the chassis dyno shows where it flashs, going to call lenny at ultimate and give him the specs so he can reset it. didn't think there would be such a huge difference. probably need to change rearend gears, and bigger tires also!
[Re: sixpacksteve]
#1345098
12/03/12 01:22 PM
12/03/12 01:22 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
My converter always flashed higher on the chassis dyno vs real world. Might be something to consider.
68 Barracuda Formula S 340
[Re: dartman366]
#1345100
12/03/12 06:35 PM
12/03/12 06:35 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
so if i had a 1500 hp motor this wouldn't flash at all?
